Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 22-10-2010, 00:22
Chris is me's Avatar
AKA: Pinecone
Re: Chainless Mecanum Drive
Not to take away from innovation and technical achievement, but I don't really see the Nonadrive as some kind of new Holy Grail in FRC drivetrains, and it is absolutely not something a team without the engineering resources to design a direct drive mecanum drive should do. It's not exactly a cheap, light, or simple drivetrain.
Unread 22-10-2010, 00:58
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
So if we're using the 6 in mecanums, what is the appropriate gear box reduction?
Unread 22-10-2010, 01:06
12.75:1 seems to be a reasonable compromise between speed and torque (more or less depending on the game, of course)
Just curious, can you share a bit with us about your team's decision process that led you to your decision to explore mecanum wheels?
Unread 22-10-2010, 01:15
FRC #2635
Our main reason for trying them now is so that we have experience with them if we decide to use them for the FRC season. We bought them last year but decided not to use them for FRC because we didn't have any experience with them and we didn't think they would work well on the ramp. We want to learn how to use them because they are one of the most manueverable drive trains. From what I saw at the Portland regional last year the teams that used them were able to position themselves very well with the ball and goal and ended up doing pretty good. Basically, we think that they could be advantagous in this years competition and we want to be able to use them if they are.
Unread 22-10-2010, 01:34
The key words in this statement are: "could be" and "if".
Right now is a really good time to do a mecanum drive as an offseason project. You get a chance for rookies to build a robot, you test out new technology, and you gain knowledge and experience.
But the problem is that when all you have is a hammer, every problem looks like a nail. When Kickoff shows up, you will be tempted to use mecanum, even if the game is reminiscent of 2002 (where high traction, great pushing and low maneuverability were great benefits). Trust me, you will be tempted.
So, what you do is you take your offseason robot and a competing drivetrain (say, 6WD drop-center, or a 4WD built from the Kitbot) and run them through a series of tests, either individually or against each other with an offense vs defense. Then you evaluate which is better.
I'll let you in on a little secret: 330 has had the capability to use mecanum drive since 2005; development/small-scale prototyping started around 2003, with a full-scale base during the 2005 build season (thanks to the Kitbot frame). The closest they've ever come was 2009 with a turning 6WD system in the middle of their robot. The only time they've used wheels with rollers in competition was omni wheels in 2010, for added agility on a 4WD. They just haven't found it advantageous to use them...yet.
Unread 22-10-2010, 01:38
AKA: Pinecone
Actually, Eric, I'd say they're doing exactly the right thing by trying it now. There's really no better of a time to see if you can get it working and learn about the drawbacks of such a system. I mean, one could say the very same thing about a six wheel drop prototype (ignore for a minute that 6 wheel drop has been consistently very successful).
If I'd say anything it's to make sure you guys are very, very critical of your final project and to make sure the advantages are actually called for in your design process, and that the disadvantages are not absolute. I would say a lot of teams that build mecanum drives get a little distracted by the whole coolness factor and build it without regard to the realities of pushing and whether or not strafing is required.
Unread 22-10-2010, 02:46
Which is exactly what I said in the second paragraph (right after pointing out the key words).
I also pointed out that just because you have an uber-widget doesn't mean that you should use it, but having it is nice because if you should use it, you can do it very quickly.
OK, so I also suggested a comparison test that should be easy to whip up come build season...
Unread 22-10-2010, 09:21
Well, there's a lot of information here on the CD forums about mecanum wheels, both pro and con. If you haven't yet searched the forums and read the links, you might want to consider doing that.
Unread 22-10-2010, 10:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Spot on about the direct-drive Mecanum setups. It's very efficient, though be sure to clean the rollers every couple of matches.
An interesting thing about nonadrive is the penta drive configuration. 5 omni wheels can be driven by 3 motors for a team with limited resources that wants agility.
- Less code complexity than most non-standard (skid) drive systems
- Less expensive than Mecanum or Killough (traditional 4-wheel Omni)
- Arguably more traction than "out-of-the-box" Mecanum, and definitely more traction than Killough
- In recent years, it would leave at least 1 CIM available for other things
- Can be used in 4WD or 6WD skid configurations, though that is highly coupled with need-based strategy
I've toyed with a concept that uses 5 wheels in nonadrive's pentadrive configuration with the middle wheel being a traction crab module that pivots via pneumatic linkage (pneumatic to keep the code simple). This concept gives a mid-grade complexity while also potentially providing some of the agile+tractive advantages of nonadrive without the weight. Of course it doesn't have the natural anti-turn capability of nonadrive, but that's the trade off. The concept was inspired by nonadrive and the limited pictures I've seen of 330's 2009 bot.
Unfortunately I've been overruled for our offseason prototype due to team survivability, so maybe another team will prototype it?
GitHub
Unread 22-10-2010, 11:15
AKA: Pinecone
I would suggest that a slide drive config that wants at least 1 CIM for something else use 1 CIM + 1 FP in the drivetrain instead of just 1 CIM. Acceleration is helped a pretty good amount.
Unread 22-10-2010, 14:53
AdamHeard's Avatar
Lead Mentor
I don't think this would work at as well as you'd hope. The crab module would only have so much normal force on it, based on CG location. On top of that, if someone to to try to rotate the robot, it wouldn't be nearly as difficult as trying to rotate a 4wd/6wd, etc... You'd also have to design carefully to ensure that when the module rotates, the module rotates relative to the floor, not the module stays in place and the robot rotates around it.
I'm making the assumption that the crab module would raise under normal operation.
Really, the best way to answer the question without building it is to do a full Free body diagram and look at the forces involved.
Unread 22-10-2010, 14:59
The only reason it worked when 330 used it in 2009 was those two extra wheels that all robots had to have. The trailer kept the robot body from being a big old turret.
Unread 24-10-2010, 19:24
FRC #2635
What ratio do the Andy Mark gear boxes come in? We have several assembled from last year so would we actually have to change them?
Also, I am new to mechanical and am not too familiar with gearboxes. What does 12.75:1 actually mean?
Unread 24-10-2010, 19:53
They are 12.75:1
It means that for every 12.75 turns of the motor shaft, the gearbox output shaft turns once. You are trading speed for torque.
Unread 24-10-2010, 19:54
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
12.75:1 is the default gear ratio for the AM toughboxes and toughbox-derived gearboxes (Nano, etc.)
12.75:1 is the ratio between the input (in this case the output of a CIM motor) and the output (The output shaft sprocket or direct-driven wheel). With it you can find the output speed and torque of a gearbox if you know the speed and torque of the motors going into it.
If you need the long output shafts (you might not) you would have to get new long output shafts from AndyMark and put them in the existing toughboxes.
Edit: Beaten to it
Kettering Motorsports
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Mecanum Drive Train Sam2197 Technical Discussion 25 16-11-2008 20:51
mecanum drive system Charger_07 Technical Discussion 5 23-01-2007 19:20
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
