Go to Post I'm now convinced that the entire 2015 season was an elaborate ploy by FIRST to get teams to stop complaining about bumpers. - Joe G. [more]
Unread 22-10-2010, 02:01
AdamHeard's Avatar
Lead Mentor
Re: pic: Stress plots related to broken output shaft
Originally Posted by M. Mellott View Post
One option that comes to mind might be to use a tool that has radii in the bottom corners (or completely rounded on the bottom and cut your groove a few thousandths deeper) rather that sharp points. Sharp edges are stress concentrators, so the blends might remove some of the stress points.
Now, one might say a completely rounded groove bottom might also take away too much of the vertical side walls of the groove and defeat the primary purpose--holding a snap ring and supporting an axial load...but some snap rings have rounded cross-sections, so...
I really think the solution is to not use snap rings in the torsionally loaded section. We've used snap rings extensively the last few seasons, and have never needed to put one centered like that.
You're talking about a groove .030-.040 wide and only .020ish deep for most snap ring sizes, not much opportunity to radius the edges there.
pic: Broken Output Shaft Jon Jack Extra Discussion 19 15-11-2010 20:47
Gearbox Output Shaft Defect Nathan2974 General Forum 2 16-01-2010 10:26
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
