#46
Re: yes comunication, yes code but no response by robot
yes the leds on the side of module change depending on which solenoids we turn on and i cant answer your last question because ever since i switched all the switches to off except console out i have not been able to communicate. |
#47
Are you saying that you can control solenoids without communication working between the Driver Station and the robot? That shouldn't be possible. What exactly isn't working? When you describe the symptoms, don't just say "not...able to communicate." Please indicate the state of the red and green status indicators on the Driver Station display, and tell us the actual words that the Driver Station displays. |
#48
they are all off except console out and so what kind problem is it
#49
If you can't give the details necessary to diagnose the problem, I can't help further, sorry.
#50
you asked what position it was in and i told you tell me what else you need
#51
Have you changed the code since it was last working? And have you tried basic vanilla code on it.
#53
Do you mean slot 1 of the cRIO chassis? The one that holds your first analog input module?
At any rate, this means you currently do not have a cRIO, and you will tell us the result when you get it back. Am I correct? |
#55
you are correct and i will let you know when we get it back
#56
I got the CRIO back and it still does not work but this time new problem we can not deploy code in java using netbeans or in C++ using windriver
--on windriver we get the error message -failed to connect to target server possibly caused by back end not connected. --on Netbeans -we get a socket exception error i dont know what these errors mean i dont care which one you could help me with but either would work. |
#57
Did whoever you got it back from tell you what they did to it? Was there actually a problem that they fixed, or did they just test it and find that it already worked as expected?
The zeroth step should be to browse http://www.usfirst.org/frccontrolsystem and familiarize yourself with what it offers. At the very least, get a printed copy of Chapter 2 (the Getting Started document). You'll want to start with step 2.6, setting up the cRIO. |
#58
The Crio does have v20 and i have reformatted it and i still get the same error message. for both when i try to deploy and i looked at the guide an i am familiar with the system and it has been set up like that but for my purpose i just have a motor attached to a jaguar in slot 1 on the sidecar. any other suggestions?? acctually now i cant ping it either but i could before Last edited by DaBossToss : 16-11-2010 at 12:17. |
#59
As pointed out earlier, pwm is generated by the digital modules, not the analog. The motor controller should be connected to a digital breakout, and that to a digital module in slot four.
Greg McKaskle |
#60
i know i under stand the set up and do have the sidecar connected to the Crio in module in slot 2 to PWM to the Crio but do you understand what soket exception:Connection reset in netbeans and failed to connect to target server in c++.
| Multidirectional Wheels Yes or No?? | LordBritten | Kit & Additional Hardware | 2 | 02-10-2005 19:15 |
| Guestbooks on websites? Yes or No? | Elgin Clock | Website Design/Showcase | 17 | 07-09-2004 18:28 |
| YES, so happy! | Tton | General Forum | 10 | 19-11-2003 21:55 |
| 3d community... yes or no? | JabzX | 3D Animation and Competition | 23 | 25-03-2003 17:23 |
