Go to Post The competition is over, I have no other FIRST-related activities to pursue–WHAT ELSE AM I GOING TO DO WITH MY LIFE BUT BROWSE CHIEF DELPHI UNTIL JANUARY???? - David8696 [more]
Unread 22-10-2010, 10:05
ethan_orion ethan_orion is offline
FTC #0071
ethan_orion will become famous soon enoughethan_orion will become famous soon enough
[FTC]: Magnetic Sensor Offset
Does anyone have a good understanding for the magnetic value offset?
My current understanding is that when I plug the Magnetic Sensor in and boot-up the nxt, it reports a value of around 32, other times 58. I'm imagining, that I would want to offset those numbers down to below 10. But i'm not sure why I would do that, rather then simply test if the value has changed by significant amount and program accordingly.
If people are using offsets, What values are you using? If not, what thoughts do you have on the magnetic sensor?
Thanks.
Unread 22-10-2010, 13:37
FTC #0071
Re: [FTC]: Magnetic Sensor Offset
Nevermind. Figured it out.
Our magnetic sensor reports a value of -5. If you offset -5, it then reports a value of 0 if we offset 50 it reports -55.
Sweet.
[FTC]: IR sensor TheIndian771 FIRST Tech Challenge 4 09-12-2009 10:01
[FTC]: Compass Sensor saaby FIRST Tech Challenge 5 26-03-2009 19:56
Magnetic Sensor on Pistons(help) DPPT1717 Pneumatics 10 12-01-2007 12:00
magnetic sensor Justin_302 Electrical 5 22-02-2005 13:32
