Go to Post Weird. On a forum where people talk about robots, we have a robot trying to talk to people. - dellagd [more]
Unread 24-10-2010, 19:04
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: Announcing FIRSTLua
triple-posing aside, I got it to compile.
I had to put a pyconfig.h file in EVERY folder in the Python subdir, please update this on your git tree
Unread 24-10-2010, 19:20
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Of you could just add the include dir in your make process. "-I"
Unread 24-10-2010, 20:59
1 * 4 != 14
when compiling it on linux, you can't edit the makefile or BAD THINGS HAPPEN
Unread 24-10-2010, 22:02
You can easily modify the makefile. It just takes a little care and understanding what the commands do. Adding the -I flag has worked for me before, and is probably used in the makefile already to include the WPILib headers.
Unread 24-10-2010, 23:06
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
What may have happened is originally the git repo included a PPC603gnu/Makefile; this generated file pointed to specific paths on my machine and is not regenerated by default. I've since removed it from the repo so now WindRiver should generate it for you with the correct include paths.
In other news, I'm now running robot teleop code in Python. I need to make a couple of release .zip's so people don't have to build it from scratch, then I'll create a new Chief Delphi thread with a formal announcement.
I also added a new branch to the repo for those using CAN bus. Unfortunately the CAN bus version needs some symbols that are only available when the CAN bus driver is installed on the robot, so I have to have two separate releases.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 24-10-2010, 23:22
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Are you sure about that? I thought the CAN drivers didn't provide the public symbols and the ones that are called by user code come from the NetworkCommunication library (for security reasons).
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 24-10-2010, 23:29
WPILib Developer
Hmm, you might be right, as the external symbols just seem to be FRC_NetworkCommunication_JaguarCANDriver_sendMessa ge/receiveMessage. I just didn't have a cRIO without CAN configured to test on today, so wasn't sure. If someone could test it to confirm, I'll merge the branch into master. If someone else doesn't get to it first, I'll test it myself on Wednesday (when I have access to the robot again). Thanks!
Unread 26-10-2010, 23:24
zombiezen's Avatar
zombiezen zombiezen is offline
AKA: Ross Light
FRC #0973 (Greyhound Robotics)
zombiezen is a jewel in the roughzombiezen is a jewel in the roughzombiezen is a jewel in the roughzombiezen is a jewel in the rough
On another note: you may want to rename your project to not use the FIRST name. FIRST recently became more sensitive about such things as they've trademarked the "FIRST" name and thus have to protect it from dilution. I named my Python port "RobotPy" for this reason; you might want to rename yours to "RobotLua" or something similar.
Good point. Renamed everything to "Greyhound Lua". Updating links shortly.
EDIT: Darn, guess I can't update the main links. Here are the new ones:
Project Page:
http://redmine.zombiezen.com/projects/greyhoundlua
README:
http://redmine.zombiezen.com/project...try/README.txt
Download:
http://redmine.zombiezen.com/project...houndlua/files
Cheers,
Ross Light
http://www.zombiezen.com/
Announcing Project Falafel/FLFL RandomStyuff General Forum 0 28-08-2010 07:53
Announcing of Penalties ShaniL Rules/Strategy 3 16-03-2009 21:27
Announcing penalties GaryVoshol General Forum 8 11-03-2008 16:47
Announcing BattleCry@WPI 8! WernerNYK Off-Season Events 90 28-08-2007 13:03
Announcing Brunswick Eruption V3.0 Mike Schroeder Off-Season Events 2 26-05-2004 23:12
