Go to Post Gotta love the blurred robots :cool: - Steven Donow [more]
Unread 24-10-2010, 15:27
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Grey Jaguar No Power Out
We have a Grey jaguar that appears to be in normal working order except it has no power coming through the output...
The device is wired properly. The device's indicator is responding appropriately to commands...we are getting full red and full green led feedback.
We just don't get any juice to the output. Is this as simple as "the jaguar is broken?"
Thanks for any insight.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 24-10-2010, 15:45
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Grey Jaguar No Power Out
I'm guessing you mean your motor doesn't move. I am also assuming you are using a DC 12 volt motor. If I am wrong tell me.
First thing to do is check the output with a voltmeter and see if you get any power through.
If that comes up flat I would check if the code thinks that out put is a victor. That has caused weird results for us.
- Arizona North
Unread 24-10-2010, 16:16
If the limit switch jumpers were missing, then you'd also get those symptoms - red/green LED but no power out.
Unread 24-10-2010, 19:44
AKA: Anthony Lapp
I checked that first. Also, this isn't an FRC application.....so there should be no mystery code issues.
The limit switch jumpers are in place.
Anthony Lapp
RobotOpen
Unread 24-10-2010, 23:24
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Are they in the right direction (vertical)? I remember someone on our team once flipped them horizontally and it did something like that
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 25-10-2010, 11:53
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
That isn't entirely accurate. When the limit switch input is open (no jumper), you will get a slow blink red indication on the LED if you try and drive the Jaguar in the direction with the open limit switch.
Are you using PWM or CAN to communicate with the Jaguar?
Is this a brand new, out of the box Jaguar?
Have you noticed any ESD (Electro Static Discharge) events?
Have you unscrewed the screw terminals completely (aka using ring terminals)?
Metal shavings in the case?
-David
Unread 25-10-2010, 12:33
AKA: Anthony Lapp
We are using PWM.
Not new.
No ESD.
We are however using ring terminals....I did notice in the manual that it says these shouldn't be removed completely. It is possible that there are metal shavings in the device.
Anthony Lapp
RobotOpen
Unread 26-10-2010, 09:54
Tony,
There is a possibility that there is shavings in the device. However, if it is an older jag, it might have succumbed to the dreaded FET driver failure. It is also possible that the current sense resistor has unsoldered itself. This leaves the low side of the output stages open. I do not know if the firmware checks for that condition but I have opened a few Jags where this has occurred. As others have hinted, be sure that the terminals have been correctly crimped by checking the output of the Jag with a voltmeter. The resistor lives near the negative input terminal (upper left when viewed from above with the jumpers toward you) and is the largest surface mount resistor in that area.
Unread 01-11-2010, 11:12
AKA: Anthony Lapp
I left this unresolved for now......I grabbed another Jaguar in the meantime.
I suspect that I will find shavings inside at some point.
Thanks for the help. I was able to get the machine up and running with no problems.
Anthony Lapp
RobotOpen
Unread 01-11-2010, 17:30
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Anthony, once upon a time the folks who make the Jaguars were excepting returns for troubleshooting. You may want to contact them (you can find them in a more than a couple threads) and see if they're still taking return / swaps. You might get lucky and get it replaced for free.
Unread 01-11-2010, 17:41
Originally Posted by Tom Line View Post
You may want to contact them ... and see if they're still taking return / swaps. You might get lucky and get it replaced for free.
As the old saying goes: "If you don't ask the question, the answer is NO"
Unread 01-11-2010, 19:15
AKA: Anthony Lapp
Good thinking....I'll ask.
Though I read in the manual explicit instructions not to completely remove the terminal screws.
I see they changed that with the Black Jaguars.
Anthony Lapp
RobotOpen
Unread 07-12-2010, 10:57
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
My team was having this exact same problem, thanks for all the possible problems to try. We ended up getting another Jag anyway, but if we can fix our broken one then at least we have a backup.
I know we've unscrewed the terminal screws several times, so we could have shavings. I don't think it's the program or jumpers, I've checked those, and I think I would have noticed if the current sense circuit was unsoldered when we opened the Jag. I saw something in the Jag manual about calibrating the PWM signal, so I might try that. It could also be one of the MOSFETs. Anyone know a way of testing if any are blown and/or how to replace a broken one?
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 07-12-2010, 14:12
Daniel,
The current sense resistor might not grab your attention if is missing. This was the case in some of the devices I inspected. Generally, when a FET goes bad, it leaves a burned area around it. The plastic FET retainer/insulator will be melted and there will be black marks on the board as well as burned circuit board traces. If the FET is open, you can measure with a VOM. Use the diode test position on your meter if it has one. In general with a failed FET gate driver, there is no visual damage. However, on several I have examined, the FEET driver chip had blown apart one corner and left a crated on the board.
Unread 07-12-2010, 15:21
dbeckwith's Avatar
Lead Programmer
I can't see that any of these problems are what's wrong with our Jag. The only visible thing I see that's different with the diagram in the manual is an extra resistor connecting R25 and R24, right under the current sense resistor. All our Jags seems to have it. The color bands go gold, yellow, purple, yellow. I realized also that the one we have that isn't working is one of the four we got in the rookie kit last year but have never used until now, so it's actually never worked, but all the others have. Is that resistor supposed to be there?
q = (2*b) | ~(2*b);
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
Power out puts ErinColleen Technical Discussion 2 21-01-2005 14:19
Grey Foam-Rubber Wheels RBrandy Technical Discussion 3 31-10-2003 01:11
Grey Daze Raven_Writer Chit-Chat 0 24-08-2003 18:45
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
