Go to Post My wife got mad at me when I told her I wanted to name our daughter Lotus. "What you mean the software?" she squawked. "No I mean the flower." I said. geeks, I swear.... - Koko Ed [more]
Unread 25-10-2010, 09:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Chainless Mecanum Drive
Originally Posted by Chris is me View Post
@JesseK: I was suggesting 1 CIM + 1 FP in each of the forward wheels and then just a CIM on the side wheel since strafing is secondary to forward motion for a slide drive (if it isn't secondary, you should probably be using a holonomic chassis). With a crab module in the center I would probably suggest 2 CIMs on that and 1 CIM + FP on the outsides (off the top of my head here, not based on math or anything)
Many teams get away with 1 CIM per side for a 10fps (or less) drive train and do just fine. Calculating the motor load based upon robot weight and gearing inefficiency puts the motor efficiency within a nominal amount of its maximum efficiency while just driving. If sound judgment is used on the drive train with respect to turning (wheel base for traction, or use of omnis, 6WD drop-center, etc), almost the same results would apply. Thus, as long as the team doesn't try to push another traction robot they'll be ok.
Your initial instinct is correct for what many teams want -- 11+ fps.
You'd also have to design carefully to ensure that when the module rotates, the module rotates relative to the floor, not the module stays in place and the robot rotates around it.
Good point, I didn't even think about that... It'd almost have to be an omni wheel at that point in order to prevent this completely.
Originally Posted by spiffyspleen View Post
Thank you guys! It looks like doing the mecanum drive is going to be a lot easier than I originally thought
The first iteration of Mecanum is always easy! If you build your drive train in the off season, play around with some extra weight. Specifically, see the effects of pushing a robot when the contact point removes traction from the front (lifts your robot slightly), and see the effects of just driving when your c.g. is too close to one of the wheels. Some interesting behaviors come out.
GitHub
crab drive vs. mecanum drive system superbotman Technical Discussion 33 06-01-2010 03:09
Mecanum Drive Train Sam2197 Technical Discussion 25 16-11-2008 20:51
mecanum drive system Charger_07 Technical Discussion 5 23-01-2007 19:20
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
