Go to Post "There are two ways to compete in this world, you can drag your competitors down, or you can rise above them. Which is better for the world in the long run?" - Karthik [more]
Unread 25-10-2010, 11:53
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: Grey Jaguar No Power Out
Originally Posted by Mark McLeod View Post
If the limit switch jumpers were missing, then you'd also get those symptoms - red/green LED but no power out.
That isn't entirely accurate. When the limit switch input is open (no jumper), you will get a slow blink red indication on the LED if you try and drive the Jaguar in the direction with the open limit switch.
Are you using PWM or CAN to communicate with the Jaguar?
Is this a brand new, out of the box Jaguar?
Have you noticed any ESD (Electro Static Discharge) events?
Have you unscrewed the screw terminals completely (aka using ring terminals)?
Metal shavings in the case?
-David
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
Power out puts ErinColleen Technical Discussion 2 21-01-2005 14:19
Grey Foam-Rubber Wheels RBrandy Technical Discussion 3 31-10-2003 01:11
Grey Daze Raven_Writer Chit-Chat 0 24-08-2003 18:45
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
