Go to Post It goes back to what Dave said last year--you can be legal and graciously professional, but still dumb. Play smart. - Billfred [more]
Unread 26-10-2010, 18:34
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Straberrie will become famous soon enough
Big Problem: "No Code" displayed on Classmate?
Hi,
The laptop that the team used to code and program broke, so we got a new computer. I loaded all the software on it and executed the updates provided on the FIRST website. I set up the static IP address to be what it has been on the previous computer ( 10.3.75.6).
Currently I am having a problem with the Crio. I used to be able to connect to the Crio from the previous laptop without a crossover, using Crio's first port. Now, with this computer, I had to use the Cross over. After i finally got the Crio to connect to the computer ( i pinged it after i connected it through the crossover), I decided to re-image the crio and used the 2010 version 20. The re-imaging was successful and the new IP allocated to the crio was 10.3.75.2. I reset the robot. I loaded the code to the Crio by connecting the computer to the Crio through a cross over ( port 1). The download was succesful. I reset the robot again.
Then, i connected the crio to the classmate now just using an ethernet, not dealing with the cross over, through port 1. I got the robot to communicate with the driver station, but the Crio Image appeared as "Unavailable" and there was "No Robot Code" when in fact I "successfully" loaded the code to the crio just moments ago.
Do any of you know what this problem could be caused by? Am i missing anything?
Any help would be really appreciated!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
Unread 26-10-2010, 18:44
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Big Problem: "No Code" displayed on Classmate?
1. What language. Java and C++ act VERY differently from LabVIEW.
2. If LabVIEW, I assume you did a full build and download?
3. I generally use a switch when tethering, so I can connect my laptop and the Driver Station at the same time.
3b. If you set the IP of your laptop to 10.3.75.5, you can install FRC Driver Station (Run the latest version of the DS Update to install it from scratch), and run DS in a window on your computer. This is super helpful when a switch is not available or you lack power to run a switch.
I don't think you missed anything. I would try to format the controller when imaging it, and downloading code again. I don't know if C++ suffers from this issue, but LabVIEW has a nasty tendency to crash the robot when the user code is too big.
Kettering Motorsports
Unread 26-10-2010, 18:49
Straberrie's Avatar
The Plague
AKA: Rebecca
Thank you for replying!
1) I am using C ++
2) Well I did build and download XD And i used the correct .out in the preferences for windriver.
3) Thank you for the tip! That would be useful; except, I want to get it to work as is now. I'll keep this in mind for after this is fixed.
I don't know if the problem has anything to do with me using a cross over cable, but it does connect.
And i formatted the controller when re-imaging the crio. I selected the 2010 version 20 update, and the classmate still displayed "not available" for crio image.
Unread 26-10-2010, 19:55
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
are you able to ftp into the cRIO? If so, try enabling NetConsole and check if any errors are being spit out
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 26-10-2010, 20:02
Straberrie's Avatar
The Plague
AKA: Rebecca
XD TO be entirely honest I haven't done the above before... ever. I guess this will be a good time to start, I'll attempt it tomorrow! Thank you for the advise.
"No Robot Code" problem Deep-Blue C/C++ 4 14-02-2010 17:57
A Big Thank you to Team 1529 "Cyber Cards" Mr.D Thanks and/or Congrats 2 16-03-2008 22:23
pic: "Paul" gets a bearhug from Big Mike Kim Masi Chit-Chat 2 10-11-2006 10:47
pic: A side of "Big Mike" nobody has seen Brandon Martus Chit-Chat 8 25-07-2006 23:09
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
