Go to Post The toughest part about that Chairman's Award was the fact that someone was cutting onions in the stands near 558/on the field while it was being read out. At least that was the excuse I'm going to use ;) - esquared [more]
Unread 26-10-2010, 20:46
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: How do i add two "True" values
For cases like these, where you have several boolean values that are used in evaluating for several situations, I use what I call a boolean state table to represent the desired functionality.
Here's a screenshot from my old software development guide:
The example this was for had a left and right drive control for inputs 1 and 2, bumper switches on 3 and 4, and an "auto navigation" toggle on input 5.
One way of coding this is to take each row and evaluate it with boolean logic, then bundle the results into a boolean array. With the boolean array you can use the following code:
-- Marshal Horn
cRIO "Magic" Values: Unresponsive Driver Station KRV NI LabVIEW 0 13-02-2009 17:33
"You've Been Sentenced" Robotics Add-On Deck Featured at the Duel on the Delaware Mr MOE General Forum 0 02-10-2008 07:32
Cannot access "double" values chantilly_team Programming 14 06-02-2005 13:39
Is the "Confirmed Game Information" rumor true? MJAdams Rumor Mill 8 02-01-2003 22:41
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
