Go to Post something i thought was impossible just happened: Brandon's awesomeness level has grown exponentially! just when you think he's at his peak, he does something new and extremely cool for CD. - Winged Wonder [more]
Go Back   Chief Delphi > Technical > Programming > Python
Thread Tools Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Unread 26-10-2010, 00:49
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
RobotPy: Python for FRC
After being inspired by Ross Light and Team 973's success in porting Lua to the cRIO (see the "Announcing FIRSTLua" thread), I have completed a port of Python to the cRIO, called RobotPy.
RobotPy is a fully functioning port of Python 3.1.2 that can be used for programming your FRC robot. The full set of WPILib functions, including CANJaguar, is available in Python via "import wpilib".
As with the Lua port,
  • Python is easier to learn than C
  • Live code reloads
  • Errors won't crash the robot
  • Python provides automatic garbage collection
  • WindRiver isn't needed after the base code is installed. Just a text editor and an FTP client.
I've performed some initial testing on Team 294's 2010 robot, including running CAN bus Jaguars and compressors and pneumatics. Examples and installation documentation are available on the website and are also included in the download. Also, the download .zip file includes a prebuilt FRC_UserProgram.out, so you don't need to have any programming software installed to get up and running (just FTP a bunch of files to your robot)! Please report any bugs you find via the RobotPy website's ticket system (note: registration is required).
RobotPy website: http://www.tortall.net/projects/robotpy/
While the download .zip doesn't include the source code, it is available via a git repository. See the Download page on the website for details.
With the exception of modules with large dependencies (e.g. databases), almost all of the Python standard library is included. So yes, you can parse XML files with expat on the robot if you so choose . Much of this is untested however (I have not tried to run the Python test suite on the robot).
Major thanks go to Ross Light and Team 973; this project would not have happened without them creating FIRSTLua first to inspire me to port Python. RobotPy uses the WPILib SWIG wrapper created by Ross, with the addition of CANJaguar. The idea of using a boot script to auto-reload the user code is also taken from FIRSTLua.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 26-10-2010, 01:18
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: RobotPy: Python for FRC
thank you so much
I'm already porting my team's high level motor grouper and pneumatics classes, I'm hoping these can be included with your permission, of course
Unread 26-10-2010, 01:42
WPILib Developer
Of course! I'd love to build up and include (maybe as a separate download) a library of team-built robot-oriented Python modules. And if anyone has suggestions on any other common/useful modules to include, I'll look at adding them as well (NumPy and SciPy come to mind, for example).
Unread 26-10-2010, 01:47
1 * 4 != 14
I have most of the common inputs that my team used coded in python for prototyping, so I will be done with the whole thing by tomorrow
Unread 26-10-2010, 02:09
If you don't get to it first, I'm going to try to port NumPy and SciPy to the cRIO. I've been using those for prototyping up control loops on my desktop, and they are really nice.
Do sockets work? That would make it easy to add a telnet server to the robot, and allow remote execution of code to aid testing. Also, does print work correctly?
Thanks again for doing this! I'm really excited.
Unread 26-10-2010, 02:22
WPILib Developer
I haven't tested sockets yet. Theoretically they should work, but a lot has to be correct for them to work, and I might have missed something.
Yes, print works correctly.
Feel free to tackle NumPy and SciPy. FYI, to date, I've been integrating C/C++ modules directly into Python/Lib and Python/Modules/ (and updating Modules/config.c to add them to _PyImport_Inittab), because it's all a static executable anyway.
Unread 26-10-2010, 02:49
Thanks for the information. Unfortunately my course load is quite high this semester, so it might be quite a number of weeks until I get to NumPy and SciPy. But they are definitely on the list of things to do, and I'll let you know when I get time and get somewhere with them.
Unread 26-10-2010, 09:44
1 * 4 != 14
where does print go?
Unread 26-10-2010, 12:39
WPILib Developer
The cRIO console. There's a couple different ways to see it; NetConsole is probably the best (see http://www.chiefdelphi.com/forums/sh...ad.php?t=80146).
Unread 26-10-2010, 18:41
1 * 4 != 14
I have basic driving functions and inputs programmed:
output.py
#Made by Sam Dodrill for Team 2412, WTFPL
from wpilib import Victor, Solenoid
import wpilib
import math
class Driver:
    def __init__(self, FL, FR, RL = None, RR = None):
        self.FLvictor = Victor(FL)
        self.FRvictor = Victor(FR)
        if RL != None and RR != None:become standard for the interpreter :)
            self.RLvictor = Victor(RL)
            self.RRvictor = Victor(RR)
            self.fourWheel = True
    def drive(self, speed):
        self.FLvictor.Set(speed)
        self.FRvictor.Set(-speed)
        if fourWheel:
            self.RLvictor.Set(speed)
            self.RRvictor.Set(-speed)
    def tankDrive(self, left, right):
        self.FLvictor.Set(left)
        self.FRvictor.Set(-right)
        if fourWheel:
            self.RLvictor.Set(left)
    def limit(self, n):
        if n > 1:
            return 1
        elif n < -1:
            return -1
        else:
            return n
    def arcadeDrive(self, speed, direction):
        left  = speed - direction
        right = speed + direction
        maxi = max(left, right)
        if maxi > 1:
            left = left/maxi
            right = right/maxi
        left = limit(left)
        right = limit(right)
        self.tankDrive(left, right)
    def holonomicDrive(self, power, slide, spin):
        fl = power + slide + spin
        fr = power - slide - spin
        rl = power - slide + spin
        rr = power + slide - spin
        fl = limit(fl);
        fr = limit(fr);
        rl = limit(rl);
        rr = limit(rr);
        self.setSpeed(fl, fr, rl, rr)
    def setSpeed(self, fl, fr, rl, rr):
        self.FLvictor.Set(fl)
        self.FRvictor.Set(-fr)
        self.RLvictor.Set(rl)
        self.RRvictor.Set(-rr)
    def goLeft(self):
        self.holonomicDrive(0, 0.5, 0)
    def goRight(self):
        self.holonomicDrive(0, -0.5, 0)
    def goForward(self):
        self.holonomicDrive(0.5, 0, 0)
    def goBackward(self):
        self.holonomicDrive(-0.5, 0, 0)
    def turnLeft(self):
        self.holonomicDrive(0, 0, -0.5)
    def turnRight(self):
        self.holonomicDrive(0, 0, 0.5)
    def stop(self):
        print("OH CRAP")
        self.drive(0)
input.py:
#made by Sam Dodrill for team 2412, but you can use it too
import wpilib, math
class Attack3:
    def __init__(self, port)
        self.joy = wpilib.Joystick(port)
    def getX(self):
        return self.joy.GetRawAxis(2)
    def getY(self):
        return self.joy.GetRawAxis(1)
    def getThrottle(self):
        return self.joy.GetRawAxis(3)
    def getTrigger(self):
        return self.joy.GetRawButton(1)
    def get2(self):
        return self.joy.GetRawButton(2)
    def get3(self):
        return self.joy.GetRawButton(3)
    def get4(self):
        return self.joy.GetRawButton(4)
    #yada yada yada, TODO: finish with all 11 buttons
def calcBuffer(self, n):
    buffers = 0.2
    if math.abs(n) < buffers:
        n = 0
    return n
class Xbox:
    def __init__(self, port):
    def getStick(self, n1, n2): #returns a list in the form of [x,y]
        r = list()
        r.append(calcBuffer(self.joy.GetRawAxis(n1)))
        r.append(calcBuffer(self.joy.GetRawAxis(n2)))
        return r
    def getLeftStick(self):
        return self.getStick(1,2)
    def getRightStick(self):
        return self.getStick(4,5)
    def getButtons(self, n1, n2, n3, n4): #returns a list in the form of [b1, b2, b3, b4]
        r = list()
        r.append(self.joy.GetRawButton(n1))
        r.append(self.joy.GetRawButton(n2))
        r.append(self.joy.GetRawButton(n3))
        r.append(self.joy.GetRawButton(n4))
        return r
    def getMainButtons(self): #returns [a,b,x,y]
        return self.getButtons(1, 2, 3, 4)
Unread 26-10-2010, 19:43
1 * 4 != 14
Code Zipped up and is attatched.
First Release, nothing fancy
Unread 26-10-2010, 23:29
WPILib Developer
I glanced at NumPy/SciPy. NumPy should be straightforward. SciPy, however, requires a Fortran compiler, which isn't included with WindRiver. It should be possible to build a cross-compiler but it will definitely take more work.
Unread 27-10-2010, 00:58
Hmm. That does complicate things. Something else to add to the list of prereqs for SciPy. It looks like some of what I assumed was in SciPy is also in NumPy (matricies, for example) so NumPy might be enough. At the very least, it'll help quite a bit.
Unread 27-10-2010, 09:14
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
This is totally awesome. When I saw the Lua thing, I was thinking the same thing, so I'm glad someone took the time to do it. I'll have to try it on the bot later.
Unread 27-10-2010, 19:42
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
I'm super excited to see this! I love Python as a langue, and I can't wait to maybe load this on a practice robot.
Follow me twitter dot com slash frc zach
Im doing something wrong here (python) Robototes2412 Programming 9 31-08-2010 00:05
Programing with Python Lord Byron Programming 5 25-08-2009 22:26
Looking for FRC teams for calendar fundraiser SciDKelly134 Fundraising 9 18-06-2009 11:55
Favorite Monty Python Sketch/Movie Joe Matt Chit-Chat 47 30-03-2004 21:45
monty python [split from thread: big jump, up to 131] Carolyn Duncan Chit-Chat 23 30-07-2001 20:46
