Go to Post The low bar will make your electronics team cry. - Joe G. [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 27-10-2010, 16:00
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
[OCCRA]: Partner Controller not linking
We've been having some trouble with our partner controller.
The main controller will link to the robot with no trouble. but when turning on the partner controller, all of the lights appear red. After turning it on and off dozens of times, they may link up but it is not likely.
Does anyone have a solution for this?
Could this be that we did something in the initial configuration? (there shouldn't have been one)
Unread 27-10-2010, 19:56
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: [OCCRA]: Partner Controller not linking
QUESTION: We've been having some trouble with our partner controller.
ANSWER:
Several possible
A. Someone did not upgrade the firmware in the controller.
B. You have the USB installed in the partner controller.
C. You did not "Link" The controller to the Cortex
D. You mixed up the Main and partner controller
All of the lights red usually point to Firmware. Do this first or see me at the event and I will fix it.
OK I must ask.... are the batteries in the correct sequence.... pay attention to the (+) and the (-).
Mike Martus
[OCCRA]: Linking Vex Transmitter and Microcontroller bernieseaholm OCCRA Programming 6 14-11-2009 18:17
[OCCRA]: Major VEX Controller Problem surferacf OCCRA Programming 1 29-10-2008 15:01
[OCCRA]: Robot Controller (electrical box) problem Kettering OCCRA Q&A 1 20-10-2008 09:03
Linking Errors: "section '????' can not fit the section. ..." Astronouth7303 Programming 3 16-01-2005 21:36
Robot Controller Not Working !?!?! Team1425 Electrical 3 24-01-2004 20:52
