Go to Post Don't worry so much about the wording of the rules but the intent of the rules. - Greg Needel [more]
Unread 27-10-2010, 22:29
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Mecanum. What's Best
Our team is trying to build a mecanum drive so we can add it to arsenal of drives. We have never made a successful mecanum drive yet. My freshman year (overdrive) we tried but our gear ratio was miscalculated and we could barely move. So now I want to make one that we can play with and possibly use (rebuilding/coding for the season of course). My questions are:
What's "best?"
-Wide, Long, or Square Frame (wide=wheels parallel to each other are farther apart than the wheels behind/in front of it, long=wheels are closer to the ones in front of/behind it than the ones parallel to it.
-Chain Driven or Direct Driven
-Field Oriented or Robot Oriented
*by best I mean in your experience what have you done and what where the upsides and downsides. what has worked well for you and what has been bad.
I have done a quick search and found how to build mecanums but nothing that shows why one might be better than another. If I missed something Please point me to it.
Unread 27-10-2010, 22:40
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Mecanum. What's Best
Look at this thread: http://www.chiefdelphi.com/forums/sh...hlight=mecanum
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 27-10-2010, 23:13
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
that thread sounds more like the code side of the drivetrain. i think the OP was looking for the physical design of the drivetrain.
i have never built one but i have seen many others. generally, you want to run them with the wheels parallel to the main direction of travel. wide will turn better but if your manipulation design does not allow for it, don't sweat it (true for all drivetrains other than crab).
as for direct vs chain, there are pros and cons:
chain- less foolproof (thown chain= not good), but has greater flexibility of tranny and motor placement. this year chain was a good choice for mecanum (and any other wheel drives). also allows far addition gear reduction via sprocket sizes
direct- very reliable (spur gears are strong and very few teams if any use multi-speed trannies for mecanum). tranny and motor location limited to next to the wheels. depending on wheel size, stock gearing may need to be reduced to give a proper amount of torque (keep in ming mecanums have less traction so torque is less of weapon).
speaking of traction, that is another issue mecanums always seem to have- they do not have much traction compared to traction wheels. this is why teams will still use crab drive even though mecanum is just as mobile and much simpler. this is a good point to keep in mind when 2011 design time come along.
Unread 27-10-2010, 23:27
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Not necessarily. For a crab-drive to turn better, it requires 4-wheel independent steering and driving, with complex software and driver interfaces (the second is harder) to align each wheel with it's arc, and drive it at the correct speed.
Most teams that I have seen have independent drive motors (If they have 111-style pods, with integrated motors), and 2 steering motors. If the sides are slaved together (both lefts with 1 steering motor, both rights with 1 steering motor) you can't turn better than a skid-steer. With the front/backs slaved together, you can rotate them in either "car" (front-steer ackerman), "forklift" (rear-steer ackerman), or both, which will help but not be as optimal as 4-wheel independents steering.
Kettering Motorsports
Unread 27-10-2010, 23:39
ratdude747's Avatar
AKA: Larry Bolan
exactly. what i was trying to saw was that wide drive tends to work better on all drives other than crap, since crab can be either depending on what directions the wheels are rotated at any given time. crab tends to throw a good amount of general rules out the window when it come to drivetrains.
crab is one of those things that is awesome if done right but disaster if done wrong... there was a team that shall remain anonymous that tried crab in 2006 and were forced to run it tank-style due to the programmers not having the members and time to program crab. the robot worked, but it could have been better had they opted not to try crab that year.
bottom line: crab takes a lot of effort to do right... if you are not sure if you can do it, it might be best not to.
Unread 28-10-2010, 00:23
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
Not necessarily. Just add two more wheels and drop the center ones and you can turn like any other skid steer bot.
"More power 'till it breaks or you win."
- Keith Carey
Unread 28-10-2010, 00:49
Aren_Hill's Avatar
Build Nifty Things
that also requires a degree of insanity dillon
A guy who likes robots.
Unread 28-10-2010, 00:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Position the wheels so the contact with the floor makes a square. This means the robot will be a bit longer than it is wide.
We made one with 8" AM wheels, driven by AM gearboxes with a bit of reduction in the chain drive.
Suspension of some sort that lets the wheels all rest on the ground with similar weight load is helpful too, so it will drive where you want it to.
Unread 28-10-2010, 10:38
Chris is me's Avatar
AKA: Pinecone
You can also turn a crab drive well by connecting diagonal pairs of wheels together (like 1717 did last year). This lets you both strafe and orient your wheels in a "diamond" pattern for turning on a dime.
Unread 28-10-2010, 12:27
Jared Russell's Avatar
Taking a year (mostly) off
This configuration lets you crab and turn in place, but turning while translating is difficult.
I actually took some time last year to analyze 25 different possible steering/driving configurations for crab drives. Basically, it combined all of the typical driving and steering configurations in a giant matrix, and figured out what drive modes (crab, tank steer in both long and wide, snake/car steering) would be possible (both with and without skidding the wheels) in each. I should probably wrap it all up into a white paper when I get a chance. I looked at:
4 drive transmissions (one per wheel)
-Steered all together
-Steered in pairs (F and B, L and R, diagonal)
-Steered individually
2 drive transmissions (F and B)
2 drive transmissions (L and R)
2 drive transmissions (diagonal)
1 drive transmission driving all wheels
The only configuration that gives you perfect (no skidding necessary) crab and turning under all possible circumstances is the 4 drive transmissions/4 steering transmissions case.
Unread 28-10-2010, 13:00
For the mathematically inclined, the above result is equivalent to Equation 3 which is derived in this white paper. It shows the necessary X and Y components of velocity at each wheel to achieve any desired vehicle simultaneous translational and rotational motion.
Using the results from Equation 3, the wheel angle for the nth wheel is -ATAN2(Vyn,Vxn), and the wheel rotational speed for the nth wheel is sqrt(Vxn^2+Vyn^2)/r.
Unread 30-10-2010, 14:04
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
just remember, you want an X, not an O
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 27-10-2010, 22:42
Originally Posted by kgzak View Post
What's "best?"
You've heard the saying in real estate: "Location, location, location".
Well, with a mecanum vehicle it's "Wheels, wheels, wheels".
If you don't have well-designed wheels nothing else matters. Well-designed wheels are very expensive. The rollers are crucial: they must have the proper contour, overlap, alignment, and mounting (bearings).
Secondary considerations are wheel mounting (high lateral stiffness) and closed-loop speed control.
Unread 30-10-2010, 14:42
kgzak's Avatar
AKA: Kris
Ok so from what I got it does not necessarily matter your ratio wide-long and the wheels have to be in an X. Thank you so much. Now does the COG have to be in the center of the wheels?
Unread 30-10-2010, 16:29
X from the top, O from the bottom.
CoG doesn't *need* to be in the center, but it helps (when some wheels start slipping before others, control gets difficult - a roughly central CoG will help to evenly distribute your normal force among the wheels).
What's the best ultrasonic? Nathan Programming 9 07-02-2008 23:02
Robot Size and Shape: What's Best? SSMike Technical Discussion 14 03-02-2007 13:39
lathes, what's best? ajlapp General Forum 16 27-08-2004 16:32
What's the best free portal software? DCA Fan Website Design/Showcase 7 04-05-2003 17:32
What's the best qualifying rounds strategy? Ken Leung General Forum 24 24-03-2002 18:25
