Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
Unread 28-10-2010, 19:24
thelittlesister's Avatar
thelittlesister thelittlesister is offline
AKA: Ally George
FRC #0316 (LuNaTeCs)
thelittlesister is just really nicethelittlesister is just really nicethelittlesister is just really nicethelittlesister is just really nice
Send a message via AIM to thelittlesister
Re: Low cost Netbooks for scouting
Originally Posted by Chris is me View Post
You can squeeze 10 hours out of them, usually not while running 3G and a bright screen backlight though. You can definitely get through half a day though, and charge them at lunch.
Personally I would recommend Wii remotes + a piece of paper for the handwritten notes, but this system saves you some typing time later so if you can afford it there are definitely advantages (it's also tons easier to use)
The inverter + FRC battery trick also works quite well and kept scouting going on all day Friday for my team in Connecticut.
What do mean Wii remotes? What do you use them for?
[FTC]: Building Low Cost Playing Field Christine3491 FIRST Tech Challenge 1 26-09-2009 08:57
Low-Cost Multi-touch Whiteboard using the Wiimote Vince lau Chit-Chat 0 24-01-2008 14:17
pic: FTC "Quad Quandary" low-cost field at CT kickoff event KathieK Extra Discussion 5 24-09-2007 16:19
Low Cost Planetary Gearbox Source... Joe Johnson Motors 32 14-11-2006 18:02
Low Cost Field BOM Andy Brockway General Forum 161 11-01-2004 08:34
