Go to Post And Dave...should I borrow someone's hair dryer from here in case the NASA truck needs some de-icing again this year? - Billfred [more]
Unread 28-10-2010, 22:59
Joachim Joachim is offline
Joachim has a spectacular aura aboutJoachim has a spectacular aura aboutJoachim has a spectacular aura about
[FTC]: Two different Tetrix servo bracket screws
My local FTC team has Tetrix servo bracket screws of two types on hand.
Both are Phillips drive pan heads, but one has a small head with longer shaft, and the other has a larger head with a shorter shaft.
The one with longer shaft is much easier to use, and allows the servo bracket bearing to be mounted on a variety of Tetrix parts. The shorter one is so short that it is difficult to mount the bearing in the servo bracket (you have to compress the washer some before the threads will even catch in the nut) and impossible to use the bearing with some other Tetrix parts.
Anyone else notice this?
Unread 29-10-2010, 10:10
Re: [FTC]: Two different Tetrix servo bracket screws
Apparently the longer screws are first-year or first- and second-year Tetrix parts, and the shorter ones came later.
The bags the long ones come out of have "made in USA" on the label. The thread length measures almost 9mm. The shorter screws have "made in China" on the bag label, and the thread length measures about 8mm, which is the length given in the CAD models. These shorter ones are what LEGO Education currently stocks.
Tetrix / LEGO Education should maybe look at whether the 8mm screws are a little short for their intended use. Most of our FTC team members cannot get them to work in the servo bracket, since it takes a lot of compression on the split washer before the threads of the screw will reach those of the nut.
Unread 02-11-2010, 12:42
pend pend is offline
Steve P.
AKA: Steve Pendergrast
FTC #0247 (Fatal Error)
pend is an unknown quantity at this point
Because the rules allow "compatible fasteners" we've been switching these out with #4 pan head screws a little longer, and we've been using #4 nylox nuts instead of the split washer. Works far better.
Unread 03-11-2010, 21:54
Our team got an answer in this year's official forum to the effect that "compatible fasteners" could not be used as axles (which they are, essentially, when they are in the center of the bearing).
Unread 15-01-2011, 15:09
Bea_Candy Bea_Candy is offline
FRC #1893
Bea_Candy is an unknown quantity at this point
Are you using a servo for your minibot? If so, do you count it against the two motor limit?
Unread 16-01-2011, 13:46
No, my local team is FTC and not building a minibot.
Unread 20-01-2011, 00:44
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Check Update #3...servos ok now in addition to two dc motors (relevent info for FRC makers of minibots of course;-)
[FTC]: Anyone new to FTC or TETRIX, READ THIS NOW! PhilBot FIRST Tech Challenge 21 04-12-2009 17:34
[FTC]: FVC (Vex) VS. FTC (Tetrix) jbbjjbt FIRST Tech Challenge 79 24-09-2009 12:39
[FTC]: VRC (VEX) AND FTC (Tetrix) jbbjjbt FIRST Tech Challenge 1 21-09-2009 14:59
[FTC]: FTC Tetrix Extra Parts Team 288 FIRST Tech Challenge 2 22-10-2008 18:30
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
