Go to Post Wait, I thought 2009 started on January 3rd... - ComradeNikolai [more]
Unread 30-10-2010, 16:44
Pi Fighter's Avatar
Pi Fighter Pi Fighter is offline
Insert Monty Python Reference Here
AKA: Trevor
FRC #1718 (Fighting Pi)
Pi Fighter has a spectacular aura aboutPi Fighter has a spectacular aura about
Team 1718 2011 Beta - Changes Thus Far
*DISCLAIMER*
The information listed here is what is being observed in the beta test by Team 1718. As such, none of this is official and all of this is subject to change.
Beta testing for the 2011 FRC controls systems in underway, and Team 1718 is currently beta testing the 2011 LabVIEW programming suite. The two major changes thus far from last year to this year are the new safety VI’s, and the death of Autonomous Iterative.
•Safety VI’s are the new watchdogs. Now, you only need to configure the safety updates in your Begin, and update them in TeleOp and Autonomous before the value reaches its target. NI created these as a simpler alternative to the watchdog commands. NI kept the watchdog commands for teams that want to continue using them.
•Autonomous Iterative is no longer a VI. Now, Autonomous Independent is the only autonomous file in the robot project. NI got rid of Iterative so there would be no confusion on the differences, and how to differentiate between the two in Begin.vi. If you want to use Autonomous Iterative (Or rather the closest thing to it), a While Loop in your autonomous is effectively the same thing.
We will continue to add new information to this thread as testing continues.
-Team 1718
Unread 30-10-2010, 17:03
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Team 1718 2011 Beta - Changes Thus Far
Do you guys have any days selected when you might do a demo? I'm not asking about content, just which box on the calendar to reserve.
Mark
Brick walls are for other people. - Randy Pausch
Unread 31-10-2010, 15:36
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Thanks for posting this! I see you also posted at forums.usfirst.org
-- Marshal Horn
Unread 04-11-2010, 17:10
lon.bushweiler lon.bushweiler is offline
FRC #0093
lon.bushweiler is an unknown quantity at this point
Both of these items sound like helpful additions (or subtractions).
Thanks for posting the information.
Unread 07-11-2010, 19:37
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Disk #2 came earlier this week and Wind River so far is just a bunch of command line tools. I haven't used it much yet, however...
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 20-11-2010, 17:16
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
dotbran is on a distinguished road
What are the specific differences between the Safety and Watchdog VIs? DO the Safety VIs function similarly to Watchdog's "Feed" VI?
Unread 22-11-2010, 08:27
The safety updates are built into the Set Speed. This way, when something isn't updated, the display will tell you which motor wasn't updated in time and was shutdown.
By default, these are on for the Robot Drive, and can be turned on with a parameter for other motors. Spinners don't need to be updated, so you may want to leave it off. An arm is something you should update often, so it would be wise to turn it on.
Greg McKaskle
Unread 22-11-2010, 13:56
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
What display are you referring to?
Are there plans to have these "disabled" statuses display on the dashboard?
-- Marshal Horn
Unread 22-11-2010, 19:46
The display that I should have defined is the error message display. The robot code will receive the errors. The default framework sends the errors to the DS. The DS displays them on the Diagnostics tab. I believe the DS sends the errors to the dashboard, but the default DB doesn't do anything with them.
Greg McKaskle
Team 1718 Beta Resources Jacob C. NI LabVIEW 5 18-12-2010 21:01
Team 1718 Beta Test Seminar - Michigan Teams Tom Line NI LabVIEW 0 15-10-2009 20:18
Pic: Team 1718 TomZ Robot Showcase 10 02-03-2008 15:29
pic: Team 1718 Treads Craig Roys Robot Showcase 11 13-02-2006 12:40
Team 498's Bot Thus Far Donut Robot Showcase 2 12-02-2006 00:49
