Go to Post Most teachers are not in it for the income, But they are definitely in it for the outcome. - Bob Steele [more]
Unread 27-10-2010, 10:42
rsdickerson rsdickerson is offline
AKA: Scott Dickerson
FRC #3459 (Team PyroTech)
rsdickerson is an unknown quantity at this point
Question Advice request: Getting started with LabView
No one on our rookie team has any experience with LabView. We do have two mentors who are software developers. They work in Java mostly. Our team decided to use LabView for rookie season (starting Jan 8th, 2010). We've downloaded the trial version of LabView 2010 and are trying to learn what we can from the examples included.
We are looking for advice on how our mentors can get up to speed on LabView so they will be able to assist the students during the build.
Unread 27-10-2010, 12:10
Re: Advice request: Getting started with LabView
There are some generic online tutorials that would help you get the basics down. For instance,
LV Mastery
The framework style has changed a little bit each year, so some of the videos are dated. They all work, and the LabVIEW they teach is all valid, it's just that the default FRC framework they start with and modify is no longer in use.
When FRC first switched to LabVIEW we used the generic student version for initial training, since the official FRC version hadn't been released. That'll give you some basic competence on a PC without the specialized FRC palettes or a control system. Testing FRC specific code can't be done without a control system anyway.
Here is the workshop material run by local NI reps:
Beginner presentation
Workshop guide
Workshop solutions
After you gain a basic understanding of dataflow vs. procedural you can take a look at the online tutorials by:
FRC Mastery videos
NI tutorials
Unread 27-10-2010, 13:22
Smile Re: Advice request: Getting started with LabView
Thank you. This should keep us busy till Jan 8th.
Unread 31-10-2010, 10:02
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
On top of what Mr. McLeod said the main thing that helped me out was just using the software and getting used to it. The main thing that needs to be learned with LabView or any programming is following logic, which comes with pratice.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 31-10-2010, 10:23
Given that you have mentors that work with java, what drove your decision to use LabVIEW?
Unread 31-10-2010, 11:01
Learning LabVIEW can be a different experience from learning other languages, especially for someone who has many years of programming in execution-flow languages like Java and C. Some people pick it up very quickly but for others the "aha!" moment for the paradigm shift from execution-flow to data-flow comes only after some effort.
Getting Started With Wireless Alphabet OJ Programming 2 30-01-2010 17:00
Getting started with CAN/Jaguar CVassos Programming 1 27-01-2010 23:43
Help Getting Started with VEX programming. Joe Johnson VEX 5 16-04-2007 09:01
Problem getting started with USB 6009 JimGRobot LabView and Data Acquisition 1 18-12-2006 09:15
Getting Started with Scripting LBK Rules Programming 2 15-01-2005 01:28
