Go to Post I think all we need now is Jenny Craig for Robots. - ErichKeane [more]
Unread 31-10-2010, 19:45
ethan_orion ethan_orion is offline
FTC #0071
ethan_orion will become famous soon enoughethan_orion will become famous soon enough
[FTC]: Increase Program Testing Speed?
How do people test their programs, quickly?
We currently deploy Labview programs and then run the FCS from 2009.
I'm wondering if folks have developed a labview program that doesn't require FCS and simply runs the code. A simple code, that you can hit the "deploy & run" button in labview to check code. Which later is embedded in the full code that receives the "enable/disable" commands from the FCS
Thanks for any thoughts on how to speed up programming checks.
Unread 31-10-2010, 20:41
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: [FTC]: Increase Program Testing Speed?
If we want to run the code on the field, we use this year's FCS with the samantha module, and download the code via bluetooth so we can keep the file open.
If we are testing something basic, we'll tether the robot with a usb cable. You can then run the code while labview is running it as well, this way you can get live feed from the robot's sensors ect and put data in while the program is running.
"Don't worry, programming can fix it"
Robot Communications dies as Motor speed increase Michael Fadaie NI LabVIEW 4 19-02-2010 00:55
Code to increase speed when joystick is pushed further JoJo5 Programming 3 06-02-2007 07:29
Gradual Speed Increase Booger Programming 2 24-07-2006 15:44
Ball speed testing after matches Ken Loyd Rules/Strategy 26 29-03-2006 22:36
Gradual increase in speed? Kevin Rugani Programming 1 27-03-2003 21:36
