Go to Post Excited and motivated students and teachers can do amazing things. - Wetzel [more]
Unread 31-10-2010, 22:16
Juliovega914 Juliovega914 is offline
FRC #0514
Juliovega914 is an unknown quantity at this point
Stepper motor questions
Hey guys. I am an alumni of FRC Team 514. I am not completely sure this is the correct location for this thread, if a moderator sees it fit, please go ahead and move it...
So, as part of a college project, we are working on developing a machine that is going to pump a very precise amount of fluid. Our basic design idea is one similar to that of a syringe pump. We are going to take a large syringe, and compress the plunger using a lead screw, which we plan on powering using a stepper motor we purchased.
Now the problem is that none of us have ever used a stepper motor before, and we are having trouble coming by anyone, professor or otherwise, who knows enough about them to recommend what kind of control board we will be needing.
The control of the system is going to be handled entirely within Labview, and we plan to do all of the controlling of the stepper motor using a National Instruments DAQ board (model 180955-01B).
What I am basically trying to learn is whether or not we will be needing a separate control board, and what kind of board we will be needing that would be compatible with our daq board. None of us really have any experience in this, so some basic information to get us started and have a working stepper motor is all I really need.
Here is a link to our motor:
http://cgi.ebay.com/177-oz-inch-STEP...em19b954 4621
Thanks!
-Rich
Unread 31-10-2010, 22:20
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: Stepper motor questions
I've built a couple CNC machines, and have had good luck with this one:
http://cgi.ebay.com/3-Axis-TB6560-CN...em3f033d 8ace
It's really easy to use, and has a parallel interface for controlling with a computer. I've never used LabView before, but I'm assuming it allows you to interface with the parallel port.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 01-11-2010, 20:20
Gdeaver Gdeaver is offline
FRC #1640
At work, I use peristaltic metering pumps to dose. what volume and and pressure are you looking at?
Unread 01-11-2010, 20:53
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
3,858,581
(google it)
Also, you might try this controller.
Richard Wallace
since 2003
Last edited by Richard Wallace : 01-11-2010 at 20:55. Reason: added link to step motor controller
Unread 02-11-2010, 01:10
FRC #0514
@Richard: This isn't an invention which we plan on applying for a patent with, just a solution to a problem which was assigned to us as a school project. Pumps like this have existed for much longer, such as the syringe pumps commonly used for the gradual injection of small amounts of fluid.
@gdeaver: We are looking to move anywhere between 1 and 1000 ml, with a precision of +-2 ml, We were going to use two 500 ml syringes, and so pressure will be very low. our stepper motor has a far higher torque than we need, we are using it because we got a deal on it.
Basically all I need is what I can do to get this motor turning under control, and I can take it from there.
Unread 02-11-2010, 07:42
Julio,
Your link indicates that the motor came with a motor driver board. The data sheet can be found here...
http://www.sanyocomponentsdirect.com...K672-340-E.pdf
With stepper motors, you need some feedback mechanism that can sense position and speed and a direction command. For your motor, it will also need a pretty hefty power supply. An FRC battery could supply the needed power or certainly a 12 volt pack of D cells would work as well. In your application, a motion limit might work but something that can sense the actual fluid flow would be better. Then you would just need to command a direction and enable the motor. Disable when the motor reaches the required distance/flow.
Unread 02-11-2010, 09:07
Stepper motors are often operated open-loop with a relative position command (relative to the startup position or some stall position established at startup).
If the stepper motor torque capability substantially exceeds the maximum expected load, it is assumed that the motor will step faithfully when commanded, which eliminates the need for feedback. Of course, if safety is paramount then this type of open-loop control may not be appropriate (for example, if something were to jam and the motor was unable to move the load, the controller would not know).
The control algorithm meters the steps at a rate slow enough that the motor will track faithfully (based on motor torque capability and expected maximum load). The algorithm keeps track of the commanded steps so it knows the position of the motor (relative to the startup position previously mentioned), without the need for a feedback sensor.
Unread 02-11-2010, 09:29
Ether,
The stated use requires some form of feedback. The user intends to control a flow of 1-1000ml +/- 2 ml.
Unread 02-11-2010, 09:32
Originally Posted by Juliovega914 View Post
@Richard: This isn't an invention which we plan on applying for a patent with, just a solution to a problem which was assigned to us as a school project. Pumps like this have existed for much longer, such as the syringe pumps commonly used for the gradual injection of small amounts of fluid...
Autosyringe (the product associated with the US patent number that I referenced above) was one of Dean Kamen's early inventions. It uses a step motor in the manner that you described. Dean purchased step motors and controllers from Hurst Mfg. (see the link in my earlier post) during the autosyringe development. When I introduced him to Dennis Hurst, the developer of those step motors and controllers, many years later at an FRC Kickoff, Dean shook his hand and said, "Thank you for making me rich."
BTW, the Hurst step motor controller still works very well.
Richard Wallace
since 2003
Unread 02-11-2010, 09:33
Ether,
That is achievable without feedback, by using the right stepper motor and the right lead screw and the right syringe, which I believe was the OP's intention. Correct me if I'm wrong Julio.
Unread 02-11-2010, 20:21
DonRotolo's Avatar
Back to humble
FRC #0832
Ether,
Al, I have to side with Ether here. I can command a stepper motor to move my PC Board drill machine's table 0.00025" at a time, repeatably and reliably, over about 10 inches - open loop. I'd have to think I could move a syringe plunger equally as precisely and accurately.
Rich, you might consider Gdeaver's response more carefully, as a peristaltic pump can do that easily with at least an order of magnitude greater precision.
Unread 03-11-2010, 09:21
Don,
As there are a number of variables here, atmospheric pressure being one, that influences flow rate, isn't some feedback needed?
Unread 03-11-2010, 11:01
Atmospheric pressure has no effect on the volume or mass of liquid ejected from a syringe for a given plunger displacement, since liquid is effectively incompressible for purposes of this project.
Unread 03-11-2010, 11:09
But the syringe is...
Unread 03-11-2010, 11:25
That has no effect. As the atmospheric pressure changes, both the inside and outside of the syringe experiences the same change in pressure. This is false only if the liquid is being ejected into a closed system whose absolute pressure is not affected by atmospheric pressure.
Stepper Motor Controling BEEKMAN Motors 2 04-12-2009 08:29
Motor and TIMS questions gauntlet General Forum 3 12-01-2009 22:52
Motor theory questions Rickertsen2 Motors 4 17-01-2006 08:08
Gearing/motor questions. Josh Siegel Motors 8 25-01-2005 09:49
