Go to Post FIRST is our Hunger Games. May the odds be ever in your favor. - GeorgeM [more]
Unread 31-10-2010, 16:49
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
[FTC]: samantha
We are unable to connect with our samantha on our bot. We have opened up the config file. created our ssid, downloaded to samantha and the white led only flashes. We open up our wireless network icon. sometimes we get the pc trying to connect to the samantha, but it looses the connection when the samantha does not talk back to it.
any help is greatly appreciated
Unread 31-10-2010, 19:42
ethan_orion ethan_orion is offline
FTC #0071
ethan_orion will become famous soon enoughethan_orion will become famous soon enough
Re: [FTC]: samantha
I had to disable any wireless connections to other routers before I could establish a computer to computer connection. I set my advanced wireless settings to "only connect to ad-hoc networks".
Good Luck.
Read through the manuals very thoroughly.
Unread 31-10-2010, 20:16
FTC #0658
Re: [FTC]: samantha
how do you disbable connection to other routers? we only have one router connected. do you mean you disabled the other networks?
I have read the manuals. which connection manual are you using? WPA , WET unsecured? ad hoc??
thanks
Unread 01-11-2010, 17:10
FTC #0071
Re: [FTC]: samantha
right click your wireless. "view available networks". "change advanced settings"
Then see the picture below. I had to select "connect to ad-hoc only. this disabled connecting to my schools network - which it wanted to do automatically.
connecting via adhoc was the manual I used.
good luck.
Unread 01-11-2010, 21:25
FTC #0658
Re: [FTC]: samantha
thanks i will give it a try
[FTC]: Samantha instructions Sasha FIRST Tech Challenge 12 20-07-2012 19:02
[FTC]: Short USB cables for Samantha Module PhilBot FIRST Tech Challenge 13 17-01-2011 17:42
[FTC]: FTC Samantha Unit Setup With WRT610N robotic321 FIRST Tech Challenge 0 21-10-2010 15:23
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
