Go to Post This is the type of thing that puts an evil glint in Dave's eye and a smile on his face... - Wetzel [more]
Unread 03-11-2010, 21:28
tsa256 tsa256 is offline
Tony Stark
AKA: Taylor S. Amarel
FRC #1124 (Uberbots)
tsa256 is an unknown quantity at this point
Send a message via AIM to tsa256 Send a message via MSN to tsa256
ADW22307 Gyro; How to wire with PWM
Hello everybody,
So this year myself an a few team members want to master the motion sensors. (Gyro, Accelerometer, etc). Unfortunately this happens to be on of the areas with little to no experience.
So the first question is, how do you wire a ADW22307 Gyro with a PWM cable. The sensors manual, shows a short diagram on how to wire it but fails to mentions how to do it with a PWM cable. The documentation states +5V, then ground; going from top to bottom on on the rate column of the gyro. What would this translate to colors on the PWM cable.
I would suspect, White, Red, and Black from top to bottom, am I wrong.
I've looked all over for an answer but have yet to find a definite answer. Any help would be greatly appreciated.
Unread 03-11-2010, 22:48
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: ADW22307 Gyro; How to wire with PWM
+5 is Red
Ground is Black
Signal is White or Yellow
--Ryan
FRC 766, 2015-, Mentor
How to wire pneumatics LuckyLotto2487 Electrical 9 11-02-2009 14:35
How To Wire The Encoder JamesByrne Electrical 6 19-01-2009 13:15
How to connect limit switches with pwm cables?????!!!!! jesusescobar Kit & Additional Hardware 4 18-02-2007 18:15
How do you wire ADXRS150EB gyro? MaxM Electrical 2 16-02-2004 13:43
How to wire a 40 Amp Breaker? dez250 Electrical 6 09-09-2003 11:17
