Go to Post Once you go hex you'll never go back. - sdcantrell56 [more]
Unread 03-11-2010, 21:30
JohnFogarty's Avatar
AKA: @doctorfogarty
[FTC]: Deadbands (axis/motor power restrictions)
Hello fellow programmers!
I am currently working on finding a solution to a probable bug which in being a programmer for the last 2 years never occurred. The base joystick to motor control has a bug in it.
4wd
motor[motorD]=joystick.joy1_y1;
motor[motorE]=joystick.joy1_y2;
motor[motorF]=joystick.joy1_y2;
motor[motorG]=joystick.joy1_y1;
It preforms the funtion, but one wheel always continues to spin even when the joystick may only be giving a output of 1 or 2. How do you implement dead bands on your analog sticks to control the motor power output.
John Fogarty
Unread 04-11-2010, 12:56
RCXRM RCXRM is offline
FTC #0245
RCXRM is an unknown quantity at this point
Re: [FTC]: Deadbands (axis/motor power restrictions)
Here is the code we've used to create deadbands:
if((joystick.joy1_y1 < 5) && (joystick.joy1_y1 > -5)) joystick.joy1_y1 = 0;
Unread 04-11-2010, 13:40
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
I dont have it right here, but ours is something like:
// since joysticks return -127 to 127 values, and since motors react in a
// rance of -100 to 100, this function adds a midpoint deadband and
// adjusts the speed to be within the expected range.
int deadband(int invalue)
   // if the value is between -27 and 27 then use
   // that as the deadband and return 0
   if (abs(invalue) < 27) return 0;
   // if the value is negative, add 27 to bring the (-27 to -127) to (0 to -100)
   if (invalue < 0) return invalue + 27;
   // if the value is not > 27 then it already exited, so - 27 and return
   return invalue - 27;
task main()
   motor[motorA] = deadband(joystick.joy1_y1);
   motor[motorB] = deadband(joystick.joy1_x1);
   motor[motorC] = deadband(joystick.joy1_y2);
   motor[motorD] = deadband(joystick.joy1_x2);
Unread 04-11-2010, 17:23
AKA: @doctorfogarty
haha that looks exactly like what I am trying today thanks
I'll just see what works best I may end up going with the other idea too but thank you for your help.
John Fogarty
GForce 3864
John Fogarty
Unread 04-11-2010, 19:03
coollog's Avatar
coollog coollog is offline
Q
AKA: Qingyang Chen
FTC #5485 (PRO)
coollog is an unknown quantity at this point
Another way to do it is
int threshold = 12;
motor[motorD] = (abs(joystick.joy1_y1) >= threshold) * joystick.joy1_y1;
This basically just zeroes any joystick value that is within a threshold of 0.
Will a 1/3 horse power sump pump motor burn up at half power? Weird Al/ Tony Motors 46 09-04-2010 21:11
Axis Camera Power polarity hurtzmyhead Electrical 4 03-02-2010 09:21
Axis 206 Camera Power Supply EricWilliams FRC Control System 1 02-02-2010 17:18
Axis Camera 206 Power Connection Matt2081 Electrical 7 24-01-2010 15:51
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
