computer requirements
My team is looking at buying some new desktop computers to run solidworks on for the next few years, and I thought it might be helpful to find out what other teams are using for computers to design their robots with.
so what i would like to know is: what are the specs of the computers that you make your CAD models with? Do you use any of the more advanced features like weldments, or do simulations of robot assemblies on the computer? If so how well does your computer handle all the features that you use? also if you have any suggestions on the matter I'd be glad to hear them. |
Re: computer requirements
Spec-wise, I'd recommend a system running, at the minimum:
As for a specific recommendation, it would help to get a price range that you're looking at. There's a lot of good computers out there for CAD work, but if you're limited on what you can spend you're going to have to tweak some of the system specs to maximize your performance, and you may have to settle for lower specs than you might like. I can say that I can run Inventor pretty well on my system, and I'm running a somewhat older Inspiron 530 with a 2.53GHz Core 2 Duo with 2GB of RAM and a GeForce 9500GT graphics card, all of which I picked up open box for a pretty good deal. I'm pretty sure the total cost of my system comes out under $400, but I'll also say that as it stands now, it could probably use another Gig or two of RAM |
I'd strongly advice a workstation graphics card if you plan on running CAD software.
If you want to run solidworks with passable performance you don't need all that much.
At work I have a 3.2 ghz P4 with 4 gigs of RAM and an Nvidia 7600 GT. Drawing individual parts works just fine with no noticeable performance issues. Small assemblies can be manipulated fairly well, though there is some delay in rendering. Large assemblies (like the size of the robot) take awhile to load and can be manipulated, but require patience. The rendering delay can be annoying as can the general lagginess while rotating or zooming. I would recommend higher specs, like Zholl listed, but you can certainly get away with less. |
I run Solidworks on a laptop with a Pentium Dual Core T2330 1.6GHz with 2 gigs of RAM. It is usable, but it doesn't work fast enough for a person without the patience for it. Especially in large assemblies.
I also have it on an older machine with a P4 2.4GHz 533MHZ FSB 512k cache with 3 Gigs DDR400 RAM and a Geforce 6200 AGP 8x 256mb card. Again, it works, but not well enough to be productive with. Go higher with specs. You don't need a dual hex-core Xeon machine. But try at least something like a Core 2 Duo, with a little more cache, higher bus speeds, DDR2 (or DDR3), a PCIe x16 graphics card, etc. As mentioned previously, the graphics card you select is going to be important. Make sure it's something that is known to work well with Solidworks. Sometimes certain cards will have their own specific glitches with software like that. I know Autodesk puts out a list of certified cards. Not sure if Solidworks does. I'll also note, I've seen it run beautifully with large assemblies in Windows on a Macbook Pro (uncertain of specs). |
Solidworks puts out a list of graphics cards that they recommend. It's somewhere on their website.
If you are trying to keep costs down, you can find used professional graphics cards on Ebay for a lot less than they are new, especially if you go back a version or two. I second the call for the CAD rated graphics cards. They work a lot on their drivers to make them more responsive. I've run both drivers (gaming and CAD) on the same card, and the CAD driver was significantly nicer to work with. |
#7
Here is a link to the Sollidworks System Requirements and there is a link to suitable graphic cards on the page http://www.solidworks.com/sw/support...uirements.html
#8
Good tips here - I am not a hardward expert put I would go
forum.solidworks.com The SolidWorks community forums is filled with information about hardware in the "Adminstration" category. Also, the community is really helpful, if you dont find what you are looking for - just ask. Marie |
#10
thanks for the good advice everyone. the mentors on my team chose to get laptops for mobility and working at home.
#11
then try to get one with an i5 equivalent or better, minumum 4 gigs ram, and a good graphics car. i'd also reccomend a larger (15+ in) screen and an external hard drive and also a bootster battery pack if you plan on working away from outlets for any length of time. as for cost, try getting a used/ refurbished laptop, they are much cheaper
#12
Avoid anything that relies on NVidia GeForce Graphics Cards for CAD. Those are specifically gaming graphics cards, there is a difference. I cannot run Inventor or even Google Sketchup when I use the GeForce graphics card. It could be my computer but I really would recommend going for something with the Nvidia Quadro Graphics card, the Quadro is the Nvidia graphics card designed for CAD specifically.
I run Inventor off the integtrated graphics on my Dell XPS with an i5 560 (2.67 gHz, turbo up to 3.3 gHz, 4 threads, 3M cache) processor and it runs incredibly fast even with large assemblies and rendering. I would recommend going for lots of RAM as well, I have 6 gB which is plenty. My dad runs solidworks on his Dell Precision with an NVidia Quadro Graphics card and it works fine. I like DELL for the warranty but I do not have any experience with anything other than DELL and HP. Except for my graphics card (I like it for games not CAD) my DELL XPS runs CAD great. With full warranty (+$300-$400) my XPS cost around $1500. I can only recommend Dell because I have only used Dell but they have served me fine. Last edited by Garret : 29-11-2010 at 23:48. Reason: Forgot some stuff |
#13
Obviously you're going to get much better performance from a workstation graphics card, but you're going to pay a MAJOR premium for it if you start shopping for workstation class laptops. I wouldn't recommend that. |
#15
As you plan to use the machines over the next few years, be certain to update graphics drivers from the manufacturers website.
Everytime you upgrade, check for driver updates. Marie |
| Computer Science or Computer Engineering? | KRibordy | College & University Education | 14 | 09-10-2009 01:56 |
| Scouting System Requirements | Guy Davidson | Scouting | 14 | 23-01-2009 17:35 |
| Thursday Animation Requirements | Darcolx | Regional Competitions | 1 | 20-02-2004 21:59 |
| 2004 Codec Requirements | SteveC116 | 3D Animation and Competition | 15 | 15-01-2004 21:53 |
| RAM Requirements | Tyler Olds | 3D Animation and Competition | 10 | 22-01-2002 18:48 |
