Where to get a replacement USB flash drive
I left the boot up flash drive given by FIRST in school over summer, doing inventory check, it was not found and hence missing from its locked location, is there any way to get a replacement or download the software so that I can fix the classmate pc by reinstalling the program given by FIRST using a usb flash drive.
I had another team copy it to dvd, but can't transfer it to a usb drive, one file named with 10---(or something) can't be copied over. Thank you. |
Re: Where to get a replacement USB flash drive
On the FRC Competition manual page, there is a link to a document called "Where to get more". It gives an email address to contact to get an existing flash drive reimaged.
The original USB key is a bootable drive. It must be copied using something like UNetbootin. Team 781 has successfully made (and installed) a backup copy of the key. As Joe Ross said, FIRST can provide you with a new image.
Last edited by perlgerl : 04-11-2010 at 17:37. Reason: Email address removed in response to a request by Jor Ross. |
Thank you for all your help, we were able to get the Classmate up and running.
| Where to buy replacement signal light | comwiz7 | Electrical | 1 | 26-01-2009 15:13 |
| Where can I get replacement green lights? | EHaskins | General Forum | 3 | 21-10-2007 19:39 |
| where do i get flash software | John Gutmann | Website Design/Showcase | 3 | 02-07-2005 17:45 |
| MPLAB on USB flash drive | ultramrw21 | Programming | 3 | 25-01-2005 21:20 |
| Where can I get sprockets, drive axles, etc. | SPARKY1688 | Kit & Additional Hardware | 1 | 13-01-2005 20:59 |
