Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 04-11-2010, 15:48
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: New Jaguar Firmware: Version 91
Does the jag have the capibility to determine a pulse width comming in on its encoder lines? If so shouldnt the Gear Tooth sensor be up for consideration as an addition to the quadrane and potinometer input?
I dont think any hardware modifications would be nessassary just an interrupt on one of the pins for raising. Set a timeout to read the pin again after 50 uS. If the signal is high then decrease the counter otherwise increase the counter.
New Jaguar Firmware: Version 90 dyanoshak CAN 3 24-03-2010 11:41
New Jaguar Firmware: Version 89 dyanoshak CAN 10 24-02-2010 10:10
Bricked black Jaguar after bad firmware update FRC4ME CAN 13 19-02-2010 16:52
New version of FIRSTclipse: 0.0.3 Astronouth7303 Programming 8 18-02-2007 21:06
New version of WPILib BradAMiller Programming 26 27-01-2007 15:49
