Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
  #31   Spotlight this post!
Unread 02-11-2010, 10:28
Re: Mecanum. What's Best
Originally Posted by Chris is me View Post
For mecanum drives I happen to be a fan of "halo style" controls
For those of us who don't play video games, could you please state what "halo style controls" means ? i.e. what mecanum function is assigned to each of the joystick axes. Thanks
  #32   Spotlight this post!
Unread 02-11-2010, 10:30
Chris is me's Avatar
AKA: Pinecone
Movement is assigned to one joystick (either forward or strafing, the robot moves in the direction the joystick is pressed), and the other joystick controls rotation / orientation. Much like Halo and other console first-person-shooters.
  #33   Spotlight this post!
Unread 02-11-2010, 14:31
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
IFor mecanum drives I happen to be a fan of "halo style" controls with independent joysticks for movement and rotation, and I don't even play Halo, but I also happen to be a very big proponent of not using a mecanum drive. I guess it just has always seemed more intuitive to me and whatever random kids drive the demo bot...
I agree with your Chris. Since the student sthat are going to drive the robot generally have played halo, or at least a game similar to it, it makes it very easy to pick up the controls. Also, if someone came up with a better way to control omnidirectional drive systems (mecanum, swerve, etc), I would consider using it. But given the number of people who already know how to use "halo controls," I doubt I would use it.
Side note: my team is prototyping a swerve drive this fall and we are using halo controls for the robot.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
  #34   Spotlight this post!
Unread 02-11-2010, 14:44
AdamHeard's Avatar
Lead Mentor
I'm a big fan of segregating different degrees of freedom to different joysticks. We currently use arcade drive on a skid steer, with on stick for throttle, and the other stick for turning. A human being is not very good at moving a stick perfectly in one axis.
I feel the same way for using the twist of a stick as the Z, that's just way too much for a driver to do with one hand, after all, he has two.
I believe, as chris described, that translation on one stick, rotation on another, is the way to go. This is the most intuitive, and worked great for us on our prototype crab.
  #35   Spotlight this post!
Unread 02-11-2010, 15:19
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
The suspended chassis is not a bad idea for mecanum wheels, but unless you need a lot of suspension travel I would just use it with a flexible chassis.
  #36   Spotlight this post!
Unread 02-11-2010, 16:05
Completely agreed. We do the same, and it has worked very nicely.
  #37   Spotlight this post!
Unread 04-11-2010, 19:02
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
mechanum don't really need any special considerations when mounting, almost any configuration will work, the main difference from tank is in the programming
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
What's the best ultrasonic? Nathan Programming 9 07-02-2008 23:02
Robot Size and Shape: What's Best? SSMike Technical Discussion 14 03-02-2007 13:39
lathes, what's best? ajlapp General Forum 16 27-08-2004 16:32
What's the best free portal software? DCA Fan Website Design/Showcase 7 04-05-2003 17:32
What's the best qualifying rounds strategy? Ken Leung General Forum 24 24-03-2002 18:25
