Go to Post 3 weeks vacation here...every single day devoted to volunteering for FIRST. Am I crazy? Yes...I am most definately crazy...but crazy has never been this much fun. - Andy Grady [more]
Unread 04-11-2010, 21:18
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Best way to start?
OK, you have a good point. However, when designing robot logic, a more procedural method makes more sense in most cases than a dataflow approach, but insofar as I have seen, LV is simply not as capable with procedural approaches.
Unread 05-11-2010, 11:48
Originally Posted by Ginto8 View Post
...when designing robot logic, a more procedural method makes more sense in most cases than a dataflow approach,...
Procedural programming obviously makes more sense to you. It does make a lot of sense to anyone who learned to program using a procedural language like C or Java or even BASIC. But dataflow programming makes at least as much sense to people who know it. I'd even say that a dataflow approach makes more sense than a more procedural method to people with a background in PLC programming or in circuit design.
You merely haven't seen far enough yet. Give it time.
LabVIEW provides two trivially easy ways to do strict procedural programming (error chaining and Sequence Structure frames), with Case and loop structures able to act just like their procedural counterparts. A moderately experienced programmer can implement a procedural algorithm directly in LabVIEW.
It takes a bit more experience to get to the point of being able to build simple frameworks to combine the best qualities of both the dataflow and the procedure-oriented viewpoints. I think a year of FRC robot programming might be just about enough time to get that experience.
Best Way Of Scoring? KingBK General Forum 18 05-01-2009 21:08
Best way to detect a bot dpeterson3 Electrical 24 04-01-2009 14:56
Best Way to Get Points SSMike Rules/Strategy 54 09-01-2008 16:46
Best way to start Torboticsmember Programming 4 06-02-2007 12:27
Best way to make money! SPDEXL Fundraising 17 21-07-2003 01:19
