Go to Post Never underestimate the power of human ingenuity. - Wetzel [more]
Unread 05-11-2010, 13:04
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: RELAY!!
Originally Posted by krudeboy51 View Post
myRobot(1, 2),
		pair1 = new Victor(1);
		pair2 = new Victor(2);
This is the source of your error. You presumably (since you didn't actually show it) have a RobotDrive member called myRobot which uses PWM channels 1 and 2. You then create 2 Victors which use PWM channels 1 and 2. These 2 channels are already in use by your robot drive object.
Unread 05-11-2010, 13:17
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: RELAY!!
Thanks for the correction Joe. After reading through the WPILib code again, I see how this is being done and agree with what you said about the resources. I also see what you mean about my code example. With the realays and digitial i/o on the same slot, it doesn't make any difference to specify the slot number in this case. I went back and put my original post in a spoiler tag to prevent confusion yet still have my bad analysis still available to learn from.
So, back to the analysis of the original error. The error clearly states that a resource is being allocated that was already allocated. I saw that Alan just posted a good suggestion that I was going to suggest next. My other suggestion (somewhat related) was to make sure there were no other places in the code that create relays, speed controllers, or analog/digital inputs on channels that were already in use for that resource type.
Unread 05-11-2010, 13:21
Re: RELAY!!
One thing to add on to this is that RobotDrive creates Jaguar objects on these channels. Based on the code it looks like you are using Victors.
You might want to look into using one of these two implementations of RobotDrive.
RobotDrive::RobotDrive(SpeedController *leftMotor, SpeedController *rightMotor, float sensitivity);
RobotDrive::RobotDrive(SpeedController &leftMotor, SpeedController &rightMotor, float sensitivity);
Unread 06-11-2010, 15:52
Re: RELAY!!
Very true. We only saw a small snippet of code and it's quite conceivable that other objects are constructed else where. Wouldn't it be nice if the error told you which allocation cause the reuse?
Relay Code dnrobotics11 C/C++ 3 08-03-2010 23:03
Relay Issues Stealth NI LabVIEW 4 16-02-2010 00:24
Relay AllocationException EHaskins Java 3 14-02-2010 15:30
Relay Robopanda6 Java 5 07-02-2010 01:08
C++ Relay Code? Happyisgood C/C++ 10 16-07-2009 14:54
