Go to Post In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits. - dlavery [more]
Unread 05-11-2010, 15:59
Re: Need help converting 2009 code to 2010
While there were some changes for the libraries from 2009 to 2010, They weren't huge. I recall only having to make a few minor changes to our code. In any case, it should be much faster to change the code then to re-implement. However, reimplementing the code is often a valuable experience, because you can always use your experience to make your code better and simpler.
Details about what exactly you are seeing would be helpful
Unread 05-11-2010, 16:14
I only remember DashboardEnable.ctl going missing from 2009, but it's been awhile.
Unread 05-11-2010, 18:43
dani692's Avatar
dani692 dani692 is offline
FRC #0692 (Fembots)
dani692 is an unknown quantity at this point
Yeah, the only one that isn't in the 2010 library is "driverstation.lvlib:dashboardenable.ctl". Is there any way to download that? Or something along those lines?
Unread 05-11-2010, 18:48
You can just create a duplicate.
The structure is referenced in the BuildDashboard... vi
or replace the dashboard code with the 2010 version
or eliminate it altogether...
Unread 05-11-2010, 19:33
Here's NI's response: http://decibel.ni.com/content/message/11956#11956
Unread 05-11-2010, 19:42
dani692's Avatar
FRC #0692 (Fembots)
OK, we copied the vi from the 2010 code and pasted it into the old code, and were able to build it successfully.
We then turned on our robot with the new code and the Driver Station said "System: WatchDog" instead of "System: Enabled." How can we fix this?
Unread 05-11-2010, 21:39
It sounds like the Watchdog isn't being fed in Teleop.vi
Are you familiar with how the Watchdog code works?
Unread 11-11-2010, 17:45
dani692's Avatar
FRC #0692 (Fembots)
This is what the watchdog looks like in teleop. The case loop with motor controls and what not is to the right. It's opened in begin.vi and killed in finish.vi. We looked at the 2010 code and it's the same. Does using the 2009 driver station instead of the classmate make a difference?
Unread 11-11-2010, 19:48
No. The type of DS will not matter. The code to the left that may be taking a long time to execute is the first thing I'd look at.
Greg McKaskle
Undeploying code. NEED HELP dnrobotics11 C/C++ 3 01-02-2009 18:33
Need help with code. hawk_11 Programming 6 06-02-2005 13:56
need help w/ joystick code willie837 Programming 6 02-02-2005 23:17
code violation...need help Vince lau Programming 4 20-02-2004 16:31
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
