Go to Post ... Imagine NOT being able to count on certain things to stay the same from year to year... It makes you wonder what sort of sick, twisted mind would do such a thing to all those innocent teams out there... - dlavery [more]
Unread 04-11-2010, 19:43
dani692's Avatar
dani692 dani692 is offline
FRC #0692 (Fembots)
dani692 is an unknown quantity at this point
Need help converting 2009 code to 2010
Hey,
My team keeps old robots around for presentations and such, and since we have some downtime now we need to make sure we can download code to our 2009 robot in case something happens. Problem is, that labview expired in January and there are some big changes in 2010. Is there a way to get around the library issues or do we have to redo the code? Thanks!
Unread 04-11-2010, 21:43
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Need help converting 2009 code to 2010
Library issues? Could you be more specific?
The code should reference the new libraries automatically.
-- Marshal Horn
Unread 05-11-2010, 15:15
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
To be honest with you it might be easier/faster to just rewrite the entire code. Especialy if you have a new programmer that needs to learn LabView. If you REALLY want to use the old code I don't know what to tell you.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 05-11-2010, 15:43
You're mostly concerned about being able to restore the existing program to the cRIO in case of emergency, right? If you won't be trying to modify the code, there's a reasonably simple solution. Just use ftp to copy the contents of the cRIO's filesystem, and stash it somewhere safe so you can put it back if necessary.
Unread 05-11-2010, 15:59
While there were some changes for the libraries from 2009 to 2010, They weren't huge. I recall only having to make a few minor changes to our code. In any case, it should be much faster to change the code then to re-implement. However, reimplementing the code is often a valuable experience, because you can always use your experience to make your code better and simpler.
Details about what exactly you are seeing would be helpful
Unread 05-11-2010, 16:14
I only remember DashboardEnable.ctl going missing from 2009, but it's been awhile.
Unread 05-11-2010, 18:43
dani692's Avatar
FRC #0692 (Fembots)
Yeah, the only one that isn't in the 2010 library is "driverstation.lvlib:dashboardenable.ctl". Is there any way to download that? Or something along those lines?
Unread 05-11-2010, 18:48
You can just create a duplicate.
The structure is referenced in the BuildDashboard... vi
or replace the dashboard code with the 2010 version
or eliminate it altogether...
Unread 05-11-2010, 19:33
Here's NI's response: http://decibel.ni.com/content/message/11956#11956
Unread 05-11-2010, 19:42
dani692's Avatar
FRC #0692 (Fembots)
OK, we copied the vi from the 2010 code and pasted it into the old code, and were able to build it successfully.
We then turned on our robot with the new code and the Driver Station said "System: WatchDog" instead of "System: Enabled." How can we fix this?
Unread 05-11-2010, 21:39
It sounds like the Watchdog isn't being fed in Teleop.vi
Are you familiar with how the Watchdog code works?
Unread 11-11-2010, 17:45
dani692's Avatar
FRC #0692 (Fembots)
This is what the watchdog looks like in teleop. The case loop with motor controls and what not is to the right. It's opened in begin.vi and killed in finish.vi. We looked at the 2010 code and it's the same. Does using the 2009 driver station instead of the classmate make a difference?
Unread 11-11-2010, 19:48
No. The type of DS will not matter. The code to the left that may be taking a long time to execute is the first thing I'd look at.
Greg McKaskle
Undeploying code. NEED HELP dnrobotics11 C/C++ 3 01-02-2009 18:33
Need help with code. hawk_11 Programming 6 06-02-2005 13:56
need help w/ joystick code willie837 Programming 6 02-02-2005 23:17
code violation...need help Vince lau Programming 4 20-02-2004 16:31
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
