Go to Post There's nothing like getting your butt kicked by the best! :D - Jared Russell [more]
Unread 05-11-2010, 20:20
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: Victor 884 Schematic Diagram
Does the signal itself go to 8 volts, or do you just have 8 volts on the "power" wire? If you just have 8 volts on the "power" wire, it doesn't matter because it doesn't actually hook up to anything in the victor.
On another note, I am curious what circuit you want to use and what you would accomplish by using it.
Jason
Victor 884 Devo1098 Electrical 6 29-06-2007 07:51
I need the 2006 Wiring Schematic Diagram SkD_nub Electrical 2 06-02-2006 14:46
Electrical Schematic/ Wiring diagram sanddrag Electrical 9 11-01-2005 12:51
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
