Re: Three Wheeled Scooter
As for motor controllers, 24V victors (VICTOR-883-24/24) from IFI would work, but you would need one per motor.
In addition to motor controllers, a micro-controller or other main controller should be used. For this the Arduino family of controllers would work. It offers I2C, analog, and PWM communications. However, 24V is too much for it, so a separate power supply might be needed. Alternatively, You could 12 volt motors with 12 volt victors (VICTOR-884-12/12) and that would reduce the complexity some, but I don't think CIMs can match that performance. It is very possible that four CIMs, Four Victor 884s, and 2 AM tough box minis cost less than two NPC-T64s and two Victor 883s, while retaining acceptable performance. But this hasn't been confirmed. I think that it's worth looking int though. EDIT: The Victor 885 might be a better match for the NPC motors. |
This is not really an application in which you need to use advanced power electronics. A simple motor pair driven on a variable power supply (many possible options here) would work pretty well. It would also save you a ton of money.
I wouldn't use CIMs. They don't have the duty cycle for it. They'll burn up.
Regarding variable power supply control.
This would provide a rather simple solution. I see this working well with a dpdt switch for forward/backward/center off with a throttle rheostat and a potentiometer for steering. The rheostat would be placed between the power supply and the pot. The output from the rheostat would connect to the center lead of the pot (wiper) and the two motors would be connected to opposite unused leads (the side leads). the dpdt switch would be connected to both battery leads in a H-bridge-like configuration (with out the break to power or break to ground options). |
Thanks for all the information. We had to do a redesign with different (read cheaper) parts. instead of the 2 wheels in the front for power and steering we're thinkking of using a bigger wheel in the back for power and probably manual steering with the front wheels. We're working on an updated parts list now and shop be done today. And Centurion I'm also going to be working on the new sketches and will post them as soon as i figure how to on this forum.
Ok here is what we have for the new parts list so far im not sure if/what else we need. I'll also edit the first post to avoid confusion.
New Parts list Part Cost Link Rear Wheel $240 http://www.monsterscooterparts.com/36vo10wadidr1.html Battery $98 http://www.monsterscooterparts.com/36vo10amphob.html Battery Charger $28 http://www.monsterscooterparts.com/36v1xlrbach.html Throttle $23 http://www.monsterscooterparts.com/cutwgrth5pin1.html Controller $40 http://www.monsterscooterparts.com/cu36v25a5co6.htmlb Total Cost $429 |
#7
Looks good.
what are you going to do for a frame, front wheel(s), and breaks? |
#9
@AdamHeard about how much run time would we get as is?
@PAR_WIG I attached some sketches i drew. They are very ruff but I hope they're clear enough to understand. We're going to be using pieces of corian and aluminum. Edit: we are probably gonna use some old bike wheels for the front. Last edited by ATCMech : 09-11-2010 at 11:31. |
| 3-wheeled robots | Gearheads1 | Technical Discussion | 16 | 08-01-2009 15:32 |
| 5 Wheeled Robot? | Rion Atkinson | Technical Discussion | 6 | 07-01-2009 21:13 |
| Almost balancing Scooter | gohan22 | Programming | 16 | 11-08-2008 16:00 |
| FIRST-made Scooter | VEN | Chit-Chat | 7 | 25-01-2006 15:36 |
| pic: super scooter | CD47-Bot | Extra Discussion | 12 | 05-08-2004 18:40 |
