hard reset for classmate
Hi,
Apparently our classmate has a damaged WPI library. What should we do? Will getting it back to manufacturer settings (using the USB flash memory supplied with the classmate) do the trick? If so, can anyone brief me on how we should do it? Thanks, Team 2215 |
Re: hard reset for classmate
just reinstall WPILib: http://first.wpi.edu/Images/CMS/Firs...te20100217.exe
So I just copy this exe to anywhere on the classmate and run it?
Should I backup anything before I do it? |
a rule of thumb seems to be to back up anything that you don't want to loose, though i doubt that the wpi lib install would cause issues, still it can't hurt to have backups
Note that the link posted above is for C++, if you are using Labview it will not do anything for your WPILib problems.
You can always restore from the image provided in the KoP on a flashdrive.
#7
Also... [off topic] How much are you allowed to do to the Classmate, hardware/software-wise? Any chance of adding memory? (I'm assuming the processor is hardwired directly to the board, what with it being that ****ed small...)[/off topic] |
#8
See R60
#9
Sorry but I might need help to restore the classmate pc second generation but I have no KOP USB restore one. Is there a way for me to get it or is it possible to download the files somewhere?
Thanks so much, Tom |
#10
That said, do you have access to an external DVD drive and a Windows XP (Home, I think...) Edition disk? |
#11
Perhaps the CD forum-master, or some charter members, could give some authoritative advice on this. |
#12
WITH THAT BEING SAID, I suppose it could be okay on this one, as it may be saving valuable database space for something more complex...like calculations on the likelihood of a water game... Back on topic, fimhk! How's that Classmate of yours doing? |
| Missing AC Adaptor for Classmate PC | DynamiteRoboKid | Kit & Additional Hardware | 2 | 10-02-2010 19:43 |
| Camera won't initialize when reset from RC - reset from OI and Power-up works, | krunal | Programming | 7 | 15-01-2007 00:13 |
| Reset Button for Vex RC's | irishninja | FIRST Tech Challenge | 5 | 18-06-2006 15:56 |
| Partitioning my hard drive for redhat | mechanicalbrain | Chit-Chat | 2 | 18-09-2005 07:25 |
| A hard decision for a college student | Elyse Holguin | Chit-Chat | 7 | 15-09-2004 19:37 |
