Go to Post The great thing about autonomous mode is that it doesn't require any additional effort from anyone else on your team... (You could do that yourself...but I've noticed that people will usually offer to do it for you, rather than let the programmer touch power tools.) - jgannon [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 03-11-2010, 11:32
ATCMech ATCMech is offline
FRC #1251
ATCMech is an unknown quantity at this point
Three Wheeled Scooter
We are working on building a 3 wheeled scooter in which there are two large wheeles in the front that are powered and control steering with 1 smaller swivel wheele in the back for stability. so far we plan on using an analog joystick. Below is our supplies so far... also, would we be able to use the speed controller below as a micro controller as well... We plan on running 24volt batteries.
Motors
$286 ea.
http://www.npcrobotics.com/products/...at=20&mode=gfx
Wheels
(front)
$73 ea.
http://www.npcrobotics.com/products/...at=21&mode=gfx
(back)
http://www.google.com/products/catal...d=0CFIQ8wIwAA#
Wheel Hubs
$20
2x
http://www.npcrobotics.com/products/...at=18&mode=gfx
NPC-PH448
Speed Controller
$145
http://www.robotcombat.com/marketplace_roboteq.html
Driver
Joystick
$35
http://www.mouser.com/ProductDetail/...pKNhOQSs/po%3d
Batteries
$65 for 2
http://www.monsterscooterparts.com/24vo10amphob.html
Fuses/Fusebox
*need help (we beleive we'll need 40A fuses)
We just wanted to make sure that all our supplies are compatible as well.
If you have any comments or suggestions we would love to hear them.......
Thanks for replying
Unread 03-11-2010, 19:09
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Three Wheeled Scooter
That does not appear to be an analog joystick, but rather an arcade style joystick, similar too the 'hat switches' on gaming joysticks.
Unread 04-11-2010, 12:03
FRC #1251
Thanks for replying. will this one work? http://www.happcontrols.com/joysticks/95017200.htm
Unread 04-11-2010, 19:41
AKA: Alan Wells
FRC #1350 (Rambots)
Yes, but it is very expensive. There are many alternatives. what kind of controller are you using? Can it interface with USB devices? Serial? Can it read resistance directly? Here is an interesting option for I2C.
Unread 05-11-2010, 12:09
FRC #1251
Wow that looks cool and doable, but we don't have much experience with these things. We aren't sure if it would work with the board :
(the top one in the left column). We really apprieciate any suggestions for other microcontrollers that might work for us.
Thanks!
Unread 05-11-2010, 15:28
Could you link to the exact speed controller you want to use to avoid confusion? The motor you have speced out has a stall torque of 110 Amps, if I'm reading things right, and the controller you listed only can source 7.5 amps continuous. Which means it won't work very well at all.
Unread 05-11-2010, 23:55
AKA: Alan Wells
FRC #1350 (Rambots)
As for motor controllers, 24V victors (VICTOR-883-24/24) from IFI would work, but you would need one per motor.
In addition to motor controllers, a micro-controller or other main controller should be used. For this the Arduino family of controllers would work. It offers I2C, analog, and PWM communications. However, 24V is too much for it, so a separate power supply might be needed.
Alternatively, You could 12 volt motors with 12 volt victors (VICTOR-884-12/12) and that would reduce the complexity some, but I don't think CIMs can match that performance.
It is very possible that four CIMs, Four Victor 884s, and 2 AM tough box minis cost less than two NPC-T64s and two Victor 883s, while retaining acceptable performance. But this hasn't been confirmed. I think that it's worth looking int though.
EDIT: The Victor 885 might be a better match for the NPC motors.
Unread 06-11-2010, 15:00
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
This is not really an application in which you need to use advanced power electronics. A simple motor pair driven on a variable power supply (many possible options here) would work pretty well. It would also save you a ton of money.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 06-11-2010, 18:30
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
I'm wondering how you're going to lay out the wheels in the front...
Are they going to be spread far apart so that the scooter can stay upright while at a standstill, or will they be close together so that it needs to be in motion to balance?
I would love to see any sketches or designs for it!
Unread 06-11-2010, 18:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I wouldn't use CIMs. They don't have the duty cycle for it. They'll burn up.
Unread 07-11-2010, 13:32
AKA: Alan Wells
FRC #1350 (Rambots)
Regarding variable power supply control.
This would provide a rather simple solution. I see this working well with a dpdt switch for forward/backward/center off with a throttle rheostat and a potentiometer for steering. The rheostat would be placed between the power supply and the pot. The output from the rheostat would connect to the center lead of the pot (wiper) and the two motors would be connected to opposite unused leads (the side leads). the dpdt switch would be connected to both battery leads in a H-bridge-like configuration (with out the break to power or break to ground options).
Unread 08-11-2010, 10:57
FRC #1251
Thanks for all the information. We had to do a redesign with different (read cheaper) parts. instead of the 2 wheels in the front for power and steering we're thinkking of using a bigger wheel in the back for power and probably manual steering with the front wheels. We're working on an updated parts list now and shop be done today. And Centurion I'm also going to be working on the new sketches and will post them as soon as i figure how to on this forum.
Unread 08-11-2010, 11:49
FRC #1251
Ok here is what we have for the new parts list so far im not sure if/what else we need. I'll also edit the first post to avoid confusion.
New Parts list
Part Cost Link
Rear Wheel $240 http://www.monsterscooterparts.com/36vo10wadidr1.html
Battery $98 http://www.monsterscooterparts.com/36vo10amphob.html
Battery Charger $28 http://www.monsterscooterparts.com/36v1xlrbach.html
Throttle $23 http://www.monsterscooterparts.com/cutwgrth5pin1.html
Controller $40
http://www.monsterscooterparts.com/cu36v25a5co6.htmlb
Total Cost $429
Unread 08-11-2010, 14:46
AdamHeard's Avatar
Lead Mentor
New Parts list
Part Cost Link
Controller $40
Total Cost $429
I would double or triple up on those batteries, 10Ah is pretty low if you want long runtimes.
Unread 08-11-2010, 18:14
AKA: Alan Wells
FRC #1350 (Rambots)
Looks good.
what are you going to do for a frame, front wheel(s), and breaks?
3-wheeled robots Gearheads1 Technical Discussion 16 08-01-2009 15:32
5 Wheeled Robot? Rion Atkinson Technical Discussion 6 07-01-2009 21:13
Almost balancing Scooter gohan22 Programming 16 11-08-2008 16:00
FIRST-made Scooter VEN Chit-Chat 7 25-01-2006 15:36
pic: super scooter CD47-Bot Extra Discussion 12 05-08-2004 18:40
