[FTC]: Autonomous LABview
We are having difficulties with our autonomous mode. Last year we had a perfectly working autonomous, but this year when we try doing it the same way (motor vi followed by a NXT time vi), regardless of what time we put into the timer vi, the motor moves one revolution and stops. When we try to run last year's auto with the new base, it works but the timer vis are ignored. Any thoughts as to why this is happening? I can post the actual files tomorrow if needed.
Re: [FTC]: Autonomous LABview
We've stopped bothering with time based auto and started encoder based, but i would still like info on why this is happening if anyone knows.
Can someone post a functioning auto mode that uses times effectively, or can you point us to some documentation on their proper use? Thanks in advance!
| [FTC]: LabVIEW Programming Template for FTC | Team 288 | FIRST Tech Challenge | 30 | 06-02-2010 17:49 |
| [FTC]: Bluetooth Problem with LabView/FTC Controller Station | James Dowd | FIRST Tech Challenge | 8 | 27-10-2009 10:40 |
| [FTC]: Tips page on using FTC Encoders with LabVIEW | PhilBot | FIRST Tech Challenge | 7 | 27-01-2009 14:00 |
| [FTC]: First problem with FTC and LabView.....? | PhilBot | FIRST Tech Challenge | 5 | 07-11-2008 10:36 |
| [FTC]: FTC Servo-Motor Problem with Labview | dnhansen | FIRST Tech Challenge | 1 | 26-10-2008 00:43 |
