Go to Post It is not necessary to draw 200 amps to move a robot through a two minute match. Rule of thumb is you robot should be able to compete for three matches without a battery change. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > Programming > Python
Thread Tools Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Unread 06-11-2010, 22:51
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Re: RobotPy: Python for FRC
Hmm. I checked out from the git repository just this morning. However, all the other files seem to match the most recent changeset, so maybe it's a client-side issue.
Anyways, I'm happy to report that I've finished porting last year's code to Python, and as a separate project, modified our existing C++ code to load Python to run an autonomous script that our drive team can edit while queuing for a match with alliance members, with surprising ease. I copied the RobotPy/Python directory and the wchar.h and wchar.c files into the old directory, expanded the include paths to include the root directory (containing the wchar files), /Python/, and /Python/Include/, and compiled. In our autonomous method I put the contents of RobotTask(), replacing ROBOTPY_BOOT with the path (on the robot) to our Python autonomous script. Then I uploaded the resulting .out file to the robot, leaving the existing Python libraries intact.
NetConsole shows many error messages about duplicate symbols when Autonomous mode starts, probably as a result of linking WPILib to the C++ code and also loading the _wpilib.out from RobotPy. However, WPILib also throws (fatal) "resource resuse [sic]" errors when WPILib instances from the Python code are not properly deleted before the script ends and the same resources are used in teleoperated code. I'm still resolving the kinks in WPILib on Python, but Python itself runs fine.
Im doing something wrong here (python) Robototes2412 Programming 9 31-08-2010 00:05
Programing with Python Lord Byron Programming 5 25-08-2009 22:26
Looking for FRC teams for calendar fundraiser SciDKelly134 Fundraising 9 18-06-2009 11:55
Favorite Monty Python Sketch/Movie Joe Matt Chit-Chat 47 30-03-2004 21:45
monty python [split from thread: big jump, up to 131] Carolyn Duncan Chit-Chat 23 30-07-2001 20:46
