Go to Post Too often teams forget that pretty isn't always good. - Al Skierkiewicz [more]
Thread Tools Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
Unread 07-11-2010, 18:51
biancs15's Avatar
biancs15 biancs15 is offline
Driver, Design and Manufacturing
AKA: Austin
FRC #0610 (Coyotes)
biancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to behold
Objects to make on the metal lathe and milling machine
Hi everyone,
I am in the mechanical section of my team, and I wanted to get some pre-season practice in on the machines before build season starts. Does anyone have ideas of something interesting or fun to make using the metal lathe and milling machine? It would be greatly appreciated.
Sincerely,
Austin Bianchini
2013 Team Co-Captain, Base driver, Head of Design and Manufacturing
2013 Waterloo Regional Finalists
2013 BAE Systems Regional Winners
2012 Arizona Regional Winners
2012 GTR East Regional Finalists
2011 Galileo Division Finalists
2011 Waterloo Regional Finalists
2011 GTR West Regional Finalists
"When in Rome"
Unread 07-11-2010, 18:57
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Objects to make on the metal lathe and milling machine
Practice cutting diameters on a shaft with the lathe. Take a piece of aluminum bar stock and cut some standard diameters for a specific length. For example, on a 1" shaft, cut 3/4" diameter for 1", 5/8 for another inch, and 1/2" for the last inch. See how close you can come (at least within 0.001" at 68 F).
For the mill, cut a precise slot (say, 3/4" wide x 3/8" deep). Using a 3/4" mill won't get you within 0.001 by the way...
Unread 08-11-2010, 00:03
biancs15's Avatar
AKA: Austin
FRC #0610 (Coyotes)
Thank you very much for the suggestion. I will definitely use this to practice for the build season.
I think its ok for now if it don't get to such a precise measurement, as long as I get the general idea of what I am creating and how I am doing it.
Again thanks, and good luck this year!
"When in Rome"
Unread 08-11-2010, 00:12
Trust me, it's easier to do it right during build season if you practice doing it right during the preseason. I'd start with Don's suggestion--but on your first one, try to hold a 0.010" tolerance. Then when you can hit .010 almost every time, 0.005". Repeat going down to 0.001".
If you can hold a 0.001" tolerance on a manual machine repeatably, you'll be in good shape. It's not exactly easy to do without practice.
For a bonus, you could try making a C-clamp. You'll need both a lathe and a mill for this; the tricky part is the screw/C interface. It can take a while to do it right; get help from whoever's advising you.
Unread 08-11-2010, 00:21
biancs15's Avatar
AKA: Austin
FRC #0610 (Coyotes)
Ok Eric. Thank you very much for the advice.
I will definitely implement this into my pre-season practice.
The C-clamp sounds like an excellent idea.
Good luck to you too!
Austin
"When in Rome"
Unread 08-11-2010, 09:17
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
To expand upon Don's suggestion:
Cut off the sections you turn on the lathe and see that they fit through slots or holes that you drill/mill into the plate. This will give you an idea of how tolerances and fits feel in real life, i.e. you will learn qualitatively the difference between 0.001" and 0.005" of clearance.
I would also try milling pockets in the plate of a specified depth, width, and length without going all the way through. This will teach you how to precisely control all 3 axis of the machine. I would also do the same pocket design in climb and regular cut directions to qualitatively learn the difference between the two.
Unread 08-11-2010, 12:34
Best Available Data
FRC #1778 (Chill Out!)
A useful place to start is "Machine Shop Projects" published by South Bend Lathe Works in the mid 1950s. The original is obviously out of print, but Lindsay Publications continues to reprint it. You can buy it direct from Lindsay (and if you get the catalog you'll probably order a dozen extra interesting books), or you can also buy it on Amazon. All of the projects result in things you can actually use. Some of the more complicated projects require castings, which South Bend no longer sells, but the majority do not. (If you were super hardcore, you could even do the castings yourself )
Projectsinmetal.com is also a repository of lots of interesting basic projects for both the mill and lathe, that are also useful.
RPI has students build miniature cannons for the introduction to shop class. They are neat, but they really don't require much precision. I'm sure you can find plans for a similar cannon without too much work.
If you want to move into some more advanced stuff, I have several books and websites for model engines too.
[EDIT] If you are going to get "Machine Shop Projects" you should also definitely get the companion book "How to Run a Lathe" by South Bend Lathe Works. Truly one of those oldy-but-goody books (Lindsay reprints the 1942 edition )! [/EDIT]
Unread 08-11-2010, 14:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You could design and build an ROV for the National Underwater Robotics Challenge. We used our old old South Bend lathe a lot to make our last ROV.
Unread 08-11-2010, 16:04
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Learn how to read mechanical drawings and fabricate parts to the specified tolerances.
We design our robots in SolidWorks before any final parts are completed; at which point every part gets a part number and mechanical drawing. That way, it doesn't matter if the parts are machined offsite by a sponsor or in our own shop by students or mentors, as long as they followed the drawing we just accumulate a giant pile of parts, and then over the course of about 7-10 days they all get assembled together.
For practice, try machining keyways into a shaft. For a greater challenge, machine stepped hex and/or keyed profiles into a shaft.
Art Dutra IV
世上无难事,只怕有心人.
Unread 08-11-2010, 16:21
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Though I have never done it, i have seen it done quite often: Create a full chess set. That will definitely take both the mill and the lathe. You will probably need a couple of curved lathe bits, but if you wanted to make a simple one, but you could just make angles rather than radii.
Something like this maybe:
http://upload.wikimedia.org/wikipedi...hessPieces.jpg
Unread 08-11-2010, 17:53
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by iCurtis View Post
definitely get the companion book "How to Run a Lathe" by South Bend Lathe Works. Truly one of those oldy-but-goody books (Lindsay reprints the 1942 edition [/EDIT]
I have an original 1932 edition and let me tell you, it's one of the handiest books around. Lathes have not changed much in 80 years.
A chess set or a cannon is indeed a challenge, but for skills more relevant to a robot, think of things like what you'd need to make for a robot. I also agree with the advice to see if you can hold 0.010" tolerance for five diameters, then work your way to 0.001". You need to figure out what works and what doesn't yourself.
Just turning stuff on the lathe without regard for tolerance won't help you much.
And all this goes for the mill, too. Nothing beats experience, and you want to turn out 10 or 20 pounds of aluminum shavings from each machine before January 8th.
Unread 08-11-2010, 17:57
AdamHeard's Avatar
Lead Mentor
I'm a big fan of not wasting time, nearly all the parts that have been made during our fall training sessions have been for prototype items, upgrades for offseason events, or tools/jigs for machining (mandrels for the lathe, some setups for the mill to make certain repeated operations easier, etc...)
Unread 09-11-2010, 08:57
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
How about a prototype wheel for the robot?
Unread 09-11-2010, 09:59
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
On 33, we make a lot of wheels and rollers throughout the season. Often we do this using a holesaw for the rough cut, and then turn the rollers round on a lathe. This season, I had some of the kids make a "collet" to do this. The collet is essentially a piece of 3/8 or 1/2" hex stock faced, and the drilled and tapped to 1/4-20 (holsaws usually use a 1/4" drill bit). I am not sure about the fun part, but it is a realatively easy and useful project.
Unread 09-11-2010, 11:31
Dick Linn's Avatar
no team (Synergy)
A 1914 edition of How to run a lathe is available for download:
http://books.google.com/books?id=sAV...page&q&f=false
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Could restoration key to make a Virtual Machine (VM) ? esutton Programming 5 15-01-2010 16:23
pic: CNC Milling Machine Gamer930 Extra Discussion 5 01-01-2009 14:06
pic: Finally, our new milling machine Mark McLeod Extra Discussion 11 23-09-2006 18:30
Gingery Lathe - Metal Sand Casting sanddrag General Forum 13 14-08-2003 21:41
How do you make objects shine??? Ydnar 3D Animation and Competition 7 07-01-2002 21:13
