Go to Post Upon entering FIRST you immediately apply Murphy's Laws. - A_Reed [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 07-11-2010, 22:37
sam_who sam_who is offline
FRC #2190
sam_who is an unknown quantity at this point
Joystick motion to CAN connected jaguar
I'm having an issue with black jags connected to the crio.
I'm using C++.
I have a logitech game pad connected to the driver station. In this particular instance, I'm using the Twist axis. When reading the axis, I can see the output swing between -1.0 <= output <= 1.0.
I'm operating the jag in speed mode. I'm monitoring the percent of throttle with the CrossTheRoadElectronics web page. Yes, I'm using the 2CAN.
I'm using the output of the Twist axis as the argument to the Set command.
myJag.Set (logitech.GetTwist () );
I find that I'm getting 99.99% throttle with only 25% axis movement.
-0.25 < axis_output < 0.25 yields -99.99% < speed < 99.99%
Using myJag.Get () confirms the 0.25 value.
I reduced the axis_output by a factor of four to compensate
myJag.Set (logitech.GetTwist () * 0.25 );
but I'd really like to know why this is the case. Can anybody help?
Can we detect if PSoC is connected or not ? gokul Programming 5 03-03-2010 11:24
CAN Jaguar enhancements JasonStern CAN 10 01-03-2010 09:38
CAN Jaguar Malfunction PranavSathy CAN 4 21-02-2010 18:32
Joystick To Jaguar Taxi Quinn Programming 1 17-02-2010 11:12
Using the same Jaguar/Controller for Joystick and buttons.... mck567 NI LabVIEW 2 09-02-2010 16:34
