Go to Post Here on CD, we are all one big FIRST team, mentoring each other. - Joe G. [more]
Unread 08-11-2010, 08:45
Re: Learning Electronics
kstl,
When I mention color code I am referring to our method which color codes everything. We use the 3M color tape wheels (available from Digikey and others). Everything is coded. The motor, the motor position on the robot, the motor wiring, the speed controller, the power wiring to the speed controller, the pwm cable (both ends) the position on the sidecar, the breaker and the breaker position on the PD.
If the red motor is not moving, you look for the red controller to see if it has power. If not, you check to see that there is a red breaker in place. If the controller is powered but showing no PWM connected, you look for the red PWM cable and make sure it is connected at both ends as it is marked. It sounds harder than it is. We use a spreadsheet with the codes marked on it for communication between the software, hardware and electrical teams so we are all on the same page.
Learning C idogis1 Programming 2 07-01-2008 19:56
Learning interfacing and basic electronics? jgarbers Electrical 9 26-05-2006 07:41
Learning Photoshop Jeffel IT / Communications 1 13-01-2005 19:11
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
learning Tyler Olds 3D Animation and Competition 3 07-05-2002 22:55
