Go to Post You mean nobody else has picked up on the hint about next year's game being called "Whack the Billfred"? - EricH [more]
Thread Tools Rating: Thread Rating: 28 votes, 5.00 average. Display Modes
Unread 08-11-2010, 09:17
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Objects to make on the metal lathe and milling machine
To expand upon Don's suggestion:
Cut off the sections you turn on the lathe and see that they fit through slots or holes that you drill/mill into the plate. This will give you an idea of how tolerances and fits feel in real life, i.e. you will learn qualitatively the difference between 0.001" and 0.005" of clearance.
I would also try milling pockets in the plate of a specified depth, width, and length without going all the way through. This will teach you how to precisely control all 3 axis of the machine. I would also do the same pocket design in climb and regular cut directions to qualitatively learn the difference between the two.
Could restoration key to make a Virtual Machine (VM) ? esutton Programming 5 15-01-2010 16:23
pic: CNC Milling Machine Gamer930 Extra Discussion 5 01-01-2009 14:06
pic: Finally, our new milling machine Mark McLeod Extra Discussion 11 23-09-2006 18:30
Gingery Lathe - Metal Sand Casting sanddrag General Forum 13 14-08-2003 21:41
How do you make objects shine??? Ydnar 3D Animation and Competition 7 07-01-2002 21:13
