Go to Post Okay, who's willing to admit they treat their robot as a pet? - Bill Moore [more]
Unread 07-11-2010, 12:08
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
[FTC]: some FCS questions
Having an issue with FCS
1. I can get the FCS to connect with the Samantha fine.
2. The Samantha and the NXT are on and the wire is connected between the two.
3. In the FCS I click on the joystick driver 1, there are two green circles to the left for the two controllers.
4. I don’t mess with the configuration. I just let the autonomous run through, but I have tried also to disable the autonomous but it does not affect the problem.
5. I go to the choose and select my Samantha.
6. It connects and I get a green window.
7. I click on the start match, if it is autonomous mode I let it go through and then restart the teleop match. If there is no autonomous called for I just start match.
8. The NXT says there is my program running.
9. But there is no response from the joysticks.
10. I know the program works as I can run it via the usb cable or through bluetooth
any help is appreciated.
Unread 07-11-2010, 18:20
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: [FTC]: some FCS questions
Are you using LABview or Robot C? The only thing i can think of is if your using LABview make sure your using the FTC read latest packet.vi instead of last year's version, as last years would work via bluetooth and usb but not wifi.
"Don't worry, programming can fix it"
Unread 07-11-2010, 20:38
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
If I understand you correctly, when the FCS starts, you do nothing at the joystick configurations page (where the green circles are on the left side)? If so, that is your problem. You need to press a button on one controller to identify it as controller one for the first team, then press a button on the second controller for the second team...... NOTE: If you have the sound turned on for your computer when you start the FCS, you should hear the program prompting to select the controller for Red 1 Driver 1 (press a button on the desired controller)....
When you bring up the window for the match, you should see two controllers assigned to the first team. If the FCS does not show controllers assigned to the position that you assign your robot, then no controller information will be sent to your robot.
Unread 08-11-2010, 07:59
FTC #0658
We are using Robot c.
When the joystick window comes up, there are two green circles to the left of the two red and two blue driver alliances. We are using 2 joysticks for one driver.
There is a question mark flashing to the right of red driver 1, we press the square driver 1 station button and the question mark goes away.
If we press the actual circles there is no response, so we assumed that by pressing the square driver 1 button the joysticks are assigned.
Do we do something further to assign the joysticks? We have noddled around and have no where to further assign the joyosticks.
thanks
Unread 08-11-2010, 08:11
ssi ssi is offline
AKA: David Spangler
Pressing the square does not assign the joysticks. You have to press a button on the joystick itself. The joysticks will be assigned in the order you push the joystick buttons. When you press a button on the joystick, the green circle will move to be beside the selected driver location. After you assign the joysticks, you should see a green circle beside each of the drive positions. When the main screen is displayed you should see two green circles under the status window for Red Team 1 (presuming you assign two joysticks to Red Team 1). When you press buttons on the joysticks, the corresponding circle will "light" up.
Unread 08-11-2010, 11:40
FTC #0658
thanks that worked. It is up and running
thanks again once again people on chief delphi bailed us out
[FTC]: Gamepad won't setup on FCS Bluedog24 FIRST Tech Challenge 10 13-02-2010 18:09
[FTC]: Questions about first time at FTC World Championship Madison FIRST Tech Challenge 19 17-12-2009 17:25
[FTC]: FTC Driving Questions KayyPii FIRST Tech Challenge 6 01-11-2008 21:26
[FTC]: FTC Labview questions Monty Python FIRST Tech Challenge 8 14-10-2008 20:03
Some Questions.... Lake Orion OCCRA 1 25-09-2001 20:20
