Go to Post Put on shows. Start new teams, FRC, FVC, or FLL. It doesn't matter. But I know that being on the robotics team has given me some of the best memories of my life, and I wouldn't want anybody else to miss out on that. - irishninja [more]
Unread 10-11-2010, 15:10
Re: Linksys Router (WRT610N V1) Connection Problem
Originally Posted by RoboElite640 View Post
My linksys router Model WRT610N V1 is connected into the modem, and when I try to use the FRC issued laptop and connect to the router. It does not connect so I reset the router, to somehow, fix the problem. Nothing seems to be working, and I was hoping if anyone could provide tips or help to solve the issue.
When you say "the modem" what device are you referring to?
Classmate ethernet port should be connected to one of the router's ethernet ports with an ethernet cable. Check?
Classmate IP address 10.xx.yy.5. Check?
Router IP address is 10.xx.yy.4. Check?
Open a browser on the Classmate and type 10.xx.yy.4 into the address box and you should see the router's setup screen. Check?
Follow the instructions in this document and tell us at which step the problems start.
going back to Linksys wireless router ahudson Programming 4 12-04-2010 17:20
Using a router other than WRT610N mgurgol General Forum 2 01-05-2009 16:50
Help for the Cisco linksys router? star_lancer Technical Discussion 2 31-01-2009 14:34
Problem Setting Up Router lingomaniac88 FRC Control System 2 14-01-2009 17:33
Linksys Router Help mtaman02 Chit-Chat 10 18-03-2004 01:04
