Go to Post Its easier to solve a problem when you have a positive attitude about it. - Arefin Bari [more]
Unread 10-11-2010, 14:54
RoboElite640 RoboElite640 is offline
FRC #0640
RoboElite640 is an unknown quantity at this point
Linksys Router (WRT610N V1) Connection Problem
My linksys router Model WRT610N V1 is connected into the modem, and when I try to use the FRC issued laptop and connect to the router. It does not connect so I reset the router, to somehow, fix the problem. Nothing seems to be working, and I was hoping if anyone could provide tips or help to solve the issue.
Unread 10-11-2010, 15:10
Re: Linksys Router (WRT610N V1) Connection Problem
When you say "the modem" what device are you referring to?
Classmate ethernet port should be connected to one of the router's ethernet ports with an ethernet cable. Check?
Classmate IP address 10.xx.yy.5. Check?
Router IP address is 10.xx.yy.4. Check?
Open a browser on the Classmate and type 10.xx.yy.4 into the address box and you should see the router's setup screen. Check?
Follow the instructions in this document and tell us at which step the problems start.
Unread 10-11-2010, 15:14
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
You say your connecting to a modem, why?
Unread 10-11-2010, 15:43
FRC #0640
I connected the router to the main modem, which is plugged into several other computers.
i dont understand what you mean by this
i typed 10.6.40.5. but nothing showed up
same thing for the classmate IP address
Unread 10-11-2010, 15:48
FRC #0640
i plugged it into the modem because i tried to connect wirelessly into the router, but it doesnt work. So i connected the router into the modem, and the laptop into the router.
Unread 10-11-2010, 15:58
Each of those words has a meaning, but together in the context of an FRC control system they don't make sense.
You've identified the router as the WRT610N, which is fine. That's what came in the Kit of Parts. But we don't know what "the main modem" is. There shouldn't be a modem anywhere in what you are doing. Help us to help you by describing it in more detail than "the modem".
What part don't you understand?
Do you know what the Classmate is?
Do you know what an ethernet port is?
Do you know what "connected to" means?
Do you know what the router is?
Do you know what an ethernet cable is?
Everything you need to do is spelled out in the Getting Started guide.
Unread 11-11-2010, 14:14
C_Tenranma's Avatar
C_Tenranma C_Tenranma is offline
Programmer
AKA: Chelsea
FRC #1865 (RoboBuffs)
C_Tenranma is an unknown quantity at this point
I have the same problem as RoboElite640. the only way we can move the robot is by plugging the laptop directly into cRIO by using another ethernet cable...
Unread 11-11-2010, 15:45
You have a modem too?
Seriously, RoboElite640's main problem at the moment appears to be insufficient experience with network components and connections in general. We can work through it, if we can get good enough answers to specific questions.
Has it ever worked wirelessly since your robot was running on a competition field at a regional event? Remember that the WGA on the robot had its wireless security activated at the regional, giving it a specific security code. If your router doesn't have the same security set up, the wireless connection will fail. Most teams are never given the WPA password, so setting the router to match is not an option.
The solution is simply to disable security on the WGA. Connect a cable from it directly to the router, use a web browser to log in to its configuration page at http://10.18.65.1/ (those middle two octets are specific to your team), and set the security to none.
Unread 12-11-2010, 14:19
C_Tenranma's Avatar
Programmer
AKA: Chelsea
i cannot access the configuration page at all though... To answer your first question, it has worked a few times after the competition, however, after that, it has not wirelessly worked at all. I've finally managed to get the router working just yesterday, the bridge is still our only problem...
Unread 12-11-2010, 14:26
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Team 358 has a great website....try looking at the Network Troubleshooting document....it is excellent!
http://www.team358.org/files/program...olSystem2009-/
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 12-11-2010, 14:50
Then you need to make sure the WGA is reset (use a paperclip to push the button behind the hole in the back) and follow the instructions in the Getting Started guide for setting it up from an out-of-the-box condition.
Unread 12-11-2010, 14:51
lots of good info here too
Here's a FAQ titled "Accessing Web-Based Utility on WGA600N"
Unread 12-11-2010, 15:13
C_Tenranma's Avatar
Programmer
AKA: Chelsea
Thank you eerybody! I will work on all the methods later on... But I may get back on here Mondayfor more help if we are still not successful. Again, Thank you!
Unread 18-11-2010, 13:57
C_Tenranma's Avatar
Programmer
AKA: Chelsea
Originally Posted by Alan Anderson View Post
...follow the instructions in the Getting Started guide for setting it up from an out-of-the-box condition.
Okay... but what exactly does that mean? (You must forgive me, I am still very new to this...)
Unread 18-11-2010, 14:14
Jon236's Avatar
AKA: Jon Mittelman
Open Chapter 2 at this link:
http://www.usfirst.org/roboticsprogr....aspx?id=10934
Jon Mittelman
going back to Linksys wireless router ahudson Programming 4 12-04-2010 17:20
Using a router other than WRT610N mgurgol General Forum 2 01-05-2009 16:50
Help for the Cisco linksys router? star_lancer Technical Discussion 2 31-01-2009 14:34
Problem Setting Up Router lingomaniac88 FRC Control System 2 14-01-2009 17:33
Linksys Router Help mtaman02 Chit-Chat 10 18-03-2004 01:04
