Go to Post This thread is so done I can almost smell the burnt. - Chris Fultz [more]
Unread 10-11-2010, 15:14
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: Linksys Router (WRT610N V1) Connection Problem
You say your connecting to a modem, why?
Unread 10-11-2010, 15:48
RoboElite640 RoboElite640 is offline
FRC #0640
RoboElite640 is an unknown quantity at this point
i plugged it into the modem because i tried to connect wirelessly into the router, but it doesnt work. So i connected the router into the modem, and the laptop into the router.
Unread 18-11-2010, 18:51
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
i think what he's trying to say is that he's using an LAN hub in between the classmate and the router because he couldn't access the wireless network
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 19-11-2010, 07:37
Chelsea,
If you follow each step (don't skip one) in the links you should be able to get some connection. Do not rule out the possibility that the router has failed. Although this is one of the newer devices, many manufacturers have been suffering with cheaply made capacitors from overseas. I had a different model Linksys die that was a little more than a year old. Bad caps in the power supply were causing all kinds of problems. If you are still having problems, try contacting the computer staff person for your school and see if they can walk you through it. If you can't do that, perhaps a team in your area might be interested in coming over to help you.
Unread 19-11-2010, 09:07
Here's what things should look like:
[CLASSMATE]===[ROUTER] o))/((o [WGA]===[cRIO]
You're saying he's talking about adding a hub in the middle of the wired connection between the classmate and the router?
[CLASSMATE]===[HUB]===[ROUTER] o))/((o [WGA]===[cRIO]
That doesn't make sense either. Your words seem clear and unambiguous to me, but I don't have a lot of confidence that they mean what you want them to.
going back to Linksys wireless router ahudson Programming 4 12-04-2010 17:20
Using a router other than WRT610N mgurgol General Forum 2 01-05-2009 16:50
Help for the Cisco linksys router? star_lancer Technical Discussion 2 31-01-2009 14:34
Problem Setting Up Router lingomaniac88 FRC Control System 2 14-01-2009 17:33
Linksys Router Help mtaman02 Chit-Chat 10 18-03-2004 01:04
