I feel like such a newbie I've created a created a camera from a viewport and now i want to make it zoom in so all you see is the biped that i have in the center...however. when i move the camera along a given axis when MAX is in Auto Key Mode, it doesnt set the motion key I could create a camera from view for each mouse wheel click but i was wondering if there was an eaiser way to do it??? ![]() |
Re: MAX and Cameras....
Are you sure you are setting each key at the right time and place?
Here is the pattern that should happen, written like a program: Autokey engage Key initial position Change current frame Move to second position Key second position Change current frame Move th third position Etc. If you are not following that it will not work the way you wish for it to. You still have to key it even though you are in auto key mode at least from my experience. I have never had it actually auto key for me, that is set the keys automatically. I have wondered that previously but have never really questioned it, I just dealt with it. If the zoom thing doesn't work right, create a line with a bunch of segments and lock the camera on the pivot points at whatever frame. make the line so that it is perpendicular to what you are zooming in on. I believe there is some kind of modifier to follow a line, but I usually just do it the long way. I hope this helps even the slightest bit! |
I don't know if this will help, but there is some good information at this site:
http://docs.autodesk.com/MAXDES/13/E...mber=d0e459384 |
| cRio and Multiple Cameras | bensherman | Electrical | 7 | 12-01-2010 07:47 |
| 3D screen and cameras | N7UJJ | Technical Discussion | 1 | 28-10-2009 01:45 |
| Turrets and cameras | Doug Leppard | Technical Discussion | 51 | 02-04-2009 12:37 |
| Two cameras: Pros and Cons | cooknl | Programming | 1 | 12-01-2006 20:57 |
| On board cameras and vision systems and robots! oh my! | archiver | 2000 | 1 | 23-06-2002 23:02 |
