Go to Post Life is unfair. Learn to deal with it or be unhappy. - Joe Johnson [more]
Unread 10-11-2010, 19:22
Lilgreenmonster's Avatar
Lilgreenmonster Lilgreenmonster is offline
FRC #0134 (Team Discovery)
Team Role: Photography
Lilgreenmonster is an unknown quantity at this point
Send a message via AIM to Lilgreenmonster
Question MAX and Cameras....
I feel like such a newbie
I've created a created a camera from a viewport and now i want to make it zoom in so all you see is the biped that i have in the center...however. when i move the camera along a given axis when MAX is in Auto Key Mode, it doesnt set the motion key
I could create a camera from view for each mouse wheel click but i was wondering if there was an eaiser way to do it???
Jared Landry
Team 134/Discovery
Multimedia/Autodesk
Grad Year: 2011
http://www.sau53.org/net9/First
SPARTANS
Unread 10-11-2010, 19:55
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: MAX and Cameras....
Are you sure you are setting each key at the right time and place?
Here is the pattern that should happen, written like a program:
Autokey engage
Key initial position
Change current frame
Move to second position
Key second position
Move th third position
Etc.
If you are not following that it will not work the way you wish for it to. You still have to key it even though you are in auto key mode at least from my experience. I have never had it actually auto key for me, that is set the keys automatically. I have wondered that previously but have never really questioned it, I just dealt with it.
If the zoom thing doesn't work right, create a line with a bunch of segments and lock the camera on the pivot points at whatever frame. make the line so that it is perpendicular to what you are zooming in on.
I believe there is some kind of modifier to follow a line, but I usually just do it the long way.
I hope this helps even the slightest bit!
Unread 10-11-2010, 23:27
MadeAtMidnight's Avatar
MadeAtMidnight MadeAtMidnight is offline
AKA: Carrie Asner
FRC #1625 (Winnovation)
MadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud of
I don't know if this will help, but there is some good information at this site:
http://docs.autodesk.com/MAXDES/13/E...mber=d0e459384
Carrie
League of Mothers founding member
"There are two ways to spread light; to be the candle, or the mirror that reflects it."
Edith Wharton
cRio and Multiple Cameras bensherman Electrical 7 12-01-2010 07:47
3D screen and cameras N7UJJ Technical Discussion 1 28-10-2009 01:45
Turrets and cameras Doug Leppard Technical Discussion 51 02-04-2009 12:37
Two cameras: Pros and Cons cooknl Programming 1 12-01-2006 20:57
On board cameras and vision systems and robots! oh my! archiver 2000 1 23-06-2002 23:02
