Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Unread 11-11-2010, 22:34
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: M$ Kinect controlling robots!
Originally Posted by Tom Bottiglieri View Post
I'd like to see how the IR time of flight measuring works in noisy environments (like say, outside or under stage lights). I'll have to get my hands on some hardware pretty soon.
Also, if the frame rate is decent enough, you may be able to spin this thing on a vertical axis for Velodyne type readings. We did this with single plane LIDARs (this project: MIT CSAIL Autonomous Forklift), and the results were pretty good.
The cool thing about the depth sensor here is most CV algorithms (edge detectors, feature finders), should just work.
Frame rate is 30 fps according to the technical specs that I have seen floating around.
I'm also very curious as to how it would perform outside. The Microsoft documentation specifically mentions making sure there is no direct sunlight on you or the Kinect when you are using it so there is probably at least some performance degradation.
Controlling Robots using a Wiimote and Gesture Recognition Dan Richardson Chit-Chat 4 29-06-2008 20:47
Controlling Two Robots at Once Richard McClellan Technical Discussion 6 30-01-2008 16:04
Controlling team 803 Programming 10 21-02-2006 13:56
Controlling motors railerobotics Programming 6 17-01-2006 17:17
