Go to Post I gave up football and a chance to be ignorant the remainder of my hs career....so ive gained more than loss - TheNotoriousKid [more]
Unread 12-11-2010, 09:51
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: M$ Kinect controlling robots!
Originally Posted by biojae View Post
Who says it has to be on the robot?
Why not use it as it was designed, and have your drivers be the controllers?
Originally Posted by basicxman View Post
That's exactly what I was saying; I realize that it is probably not FIRST-competition reliable but would still be cool in other environments.
Originally Posted by Wikipedia
The Kinect sense has a practical ranging limit of 1.2–3.5 metres (3.9–11 ft) distance
Standing far enough back from the controls for Kinect to properly sensor a driver means that driver has to stand at the very rear of the driver's station. Additionally, both the Driver Coach and the other Driver have to make sure they do not interfere with Kinect's imaging. Finally, every couple of years the human players are also confined to the driver's station; thus any of the HP's movement would have to keep from interfering with the Kinect as well.
By all means file it under 'neat' and 'innovative' -- so long as it's not within a competition robot driver controls context.
GitHub
Last edited by JesseK : 12-11-2010 at 09:55. Reason: Communication is iterative...
Unread 12-11-2010, 10:41
Using it on the driver station would also seem to be in technical violation of the Autonomous rules, where you would be able to use the controls from behind the autonomous driver line.
Unread 14-11-2010, 23:58
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
https://github.com/OpenKinect/libfreenect
Thats the working link.
Now how would we change the motors to legal ones?
Unread 15-11-2010, 00:08
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The two options I would look at would be ditching the motors altogether or attaching some type of servo powered pan-tilt mount externally. I haven't yet gotten the chance to pull one apart, but the images I've seen seem to suggest that it's packed pretty tight so fitting a servo inside the base may be difficult or impossible.
Unread 15-11-2010, 00:25
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Actually I ditch the idea of kinect all together, going back to my old idea which seems like the best way for me
Unread 15-11-2010, 00:01
NickE's Avatar
NickE NickE is offline
_
In theory, the coach could also control the robot, which could be an issue.
Controlling Robots using a Wiimote and Gesture Recognition Dan Richardson Chit-Chat 4 29-06-2008 20:47
Controlling Two Robots at Once Richard McClellan Technical Discussion 6 30-01-2008 16:04
Controlling team 803 Programming 10 21-02-2006 13:56
Controlling motors railerobotics Programming 6 17-01-2006 17:17
