Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 12-11-2010, 12:02
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Welding Advice
Originally Posted by Dick Linn View Post
The Diversion 180 model does include a foot pedal.
I see that from Miller it is not included, but from CyberWeld it is. Weird.
Unread 12-11-2010, 16:50
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Welding Advice
You must use a stainless steel brush to clean aluminum, any carbon steel brush will leave impurites. This is what I was told by TIG welders and also from my own experience.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 12-11-2010, 21:37
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Welding Advice
Aluminum must be absolutely clean for successful welding. Sanding or grinding should be done with a tool dedicated to Aluminum only. Degrease with a solvent but DO NOT use anything containing a chlorinated hydrocarbon! Brush away any oxides just prior to welding using a stainless steel brush that is dedicated for use on Aluminum only.
Originally Posted by Katie_UPS View Post
Never underestimate the value in Proper Surface Preparation.
It cannot be over-emphasized: ANY (any!) steel dust or even molecules will cause an Aluminum weld to be weak. ONLY Stainless steel brushes may be used, and these must never be used for any other metal. Get a small angle grinder as well.
Cleanliness is difficult but essential for welding aluminum. It oxidizes in a few seconds. Weld an inch or two, stop & clean, repeat.
Welding generates a lot of heat, and your metal will crack from thermal stress if you try to weld a long bead as one might attempt in steel. An inch at a time.
Acetone makes a suitable solvent, but of course it is dangerous and flammable.
Practice, practice, practice.
Unread 13-11-2010, 21:59
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
Re: Welding Advice
I am kinda the head mechanical mentor for team 1098. That is exactly the welder I bought personally and let the team use it. I have taught about 8 students how to use it. They have been training new students each year. I supervise this process but that welder is quite forgiving and works very well. Our students do 100% of our design, fabrication, programming, machining as well as the welding. Our expierenced welders do not use auto helmets, they as well as I hate them, but they are good teaching tool.
As a welder I think there is lots of good info here.
Unread 18-11-2010, 20:58
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Welding Advice
when you get a auto-darken hood, try to get a multi-setting one, because you will likely be using the hood for multiple welders that have different required darkness
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 18-11-2010, 21:30
Dick Linn's Avatar
no team (Synergy)
Re: Welding Advice
My son uses both fixed-shade and auto-dark helmets. He says if you're running a lot of long beads that the fixed-shade is nice and more clear. If you have a lot of short welds and tacks, an auto-dark is convenient. He also likes the fixed shade helmets with the flip-down lens. Less neck strain.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 03-12-2010, 11:21
jmichaelis jmichaelis is offline
AKA: Joe Michaelis
FRC #2709
jmichaelis is an unknown quantity at this point
Re: Welding Advice
Thank you all for the incredibly well thought out and thorough responses and advice. I think the best advice has been to reach out to an experienced welder locally. I'm currently hunting down a few leads with area colleges and pros, but if you have suggestions for someone from the Chicago area I'd be grateful. Again thanks for the huge response, its been really very valuable.
Unread 03-12-2010, 15:29
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: Welding Advice
For the biggest bang for your buck take a look at pop rivet technology. Joining two pieces of metal with pop rivets is fast and economical and in most cases can substitute for welding. As a mentor for the team I encourage the team to try to make use of fastener technology like pem nuts, nuts and bolts, and pop rivets before resorting to welding to join metal.
Roy
Unread 03-12-2010, 18:25
Dick Linn's Avatar
no team (Synergy)
Re: Welding Advice
In some cases, Team 975 used 10-32 cap screws to assemble a frame. Very strong and surprisingly cheap for a box of 100. Nyloc nuts were inexpensive as well. We got them at MSC.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 12-12-2010, 13:11
jtus jtus is offline
AKA: Just Jack
Rookie Year: 1994
jtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of lightjtus is a glorious beacon of light
Re: Welding Advice
Get a MIG. Miller has a lot of good options. It will weld aluminum much easer than TIG. Have someone help with the set up and you will have nice welds with little practice.
We have 2 mig wielders one for aluminum and one for steel. We also have a TIG but only two people can use it at all.
welding table Bruceb General Forum 17 17-03-2009 18:07
Welding Shira Technical Discussion 9 08-01-2009 20:23
Welding? tgwalker Rules/Strategy 16 17-01-2008 15:15
No welding? Katie Reynolds Rules/Strategy 7 20-02-2003 17:33
WELDING BOOTY BURGLAR OCCRA 2 05-10-2001 21:22
