Re: Linksys Router (WRT610N V1) Connection Problem
i cannot access the configuration page at all though... To answer your first question, it has worked a few times after the competition, however, after that, it has not wirelessly worked at all. I've finally managed to get the router working just yesterday, the bridge is still our only problem...
Team 358 has a great website....try looking at the Network Troubleshooting document....it is excellent!
http://www.team358.org/files/program...olSystem2009-/ |
Then you need to make sure the WGA is reset (use a paperclip to push the button behind the hole in the back) and follow the instructions in the Getting Started guide for setting it up from an out-of-the-box condition.
Okay... but what exactly does that mean? (You must forgive me, I am still very new to this...)
Open Chapter 2 at this link:
http://www.usfirst.org/roboticsprogr....aspx?id=10934 |
There's also an easily-remembered alias:
http://www.usfirst.org/frccontrolsystem There are links from that page to pretty much everything you need to know. Chapter 2 in particular has sections containing step-by-step instructions for setting up each of the components. |
#7
#8
Thank you eerybody! I will work on all the methods later on... But I may get back on here Mondayfor more help if we are still not successful. Again, Thank you!
| going back to Linksys wireless router | ahudson | Programming | 4 | 12-04-2010 17:20 |
| Using a router other than WRT610N | mgurgol | General Forum | 2 | 01-05-2009 16:50 |
| Help for the Cisco linksys router? | star_lancer | Technical Discussion | 2 | 31-01-2009 14:34 |
| Problem Setting Up Router | lingomaniac88 | FRC Control System | 2 | 14-01-2009 17:33 |
| Linksys Router Help | mtaman02 | Chit-Chat | 10 | 18-03-2004 01:04 |
